Top-End Redo
  • urankjj
  • urankjj's Avatar
Re: Top-End Redo
18 Aug 2019 18:58
#809432
Keep in mind that ferrous and non-ferrous metals used in conjunction are not a good idea in most scenarios.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
Re: Top-End Redo
18 Aug 2019 19:01
#809434
Glad it worked for you.
Use what works for you.
I still swear by wire o rings around the cylinders for Boosted Motors
The following user(s) said Thank You: baldy110, daveo, urankjj
  • SWest
  • SWest's Avatar
  • 10 22 2014
The following user(s) said Thank You: daveo, urankjj
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Re: Top-End Redo
18 Aug 2019 19:21 - 18 Aug 2019 19:41
#809439
Thanks Dave. So a gasket made for a 74mm bore will be larger than that after it gets compressed.
That means the Kawasaki piston oversize bores must max out close to 73mm. to work with that Kaw gasket...:huh:
Got it!
Take this thread wherever it goes...please!
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 18 Aug 2019 19:41 by daveo.
  • Away
  • Moderator
  • Moderator
Re: Top-End Redo
18 Aug 2019 19:24
#809440
I would highly suggest e mail Joe Hooper at Pitstop for pistons and gaskets
He is a expert and his prices are the best for MTC kits and many other parts
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
18 Aug 2019 19:32
#809441
Joe recommended the MTC kit, and now I'm better edumicated to carry our conversation forward.
Thanks again!
:woohoo:
  • old_kaw
  • old_kaw's Avatar
Re: Top-End Redo
18 Aug 2019 20:38
#809445
1981 Kawasaki Kz1000K1
The following user(s) said Thank You: daveo, Street Fighter LTD
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
19 Aug 2019 09:39
#809467
old_kaw wrote: www.pitstopperformance.com/top-end-assembly/[/quote
With this piston upgrade will she be noticeably different from an operation and performance viewpoint?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Top-End Redo
19 Aug 2019 10:07
#809469
Maybe a ;little more UMPH. :woohoo:
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
19 Aug 2019 10:45
#809472
SWest wrote: Maybe a ;little more UMPH. :woohoo:
My wife says I need that...so I must have her go ahead! :woohoo: :woohoo: :woohoo:
:whistle:
  • daveo
  • Premium Member
  • Premium Member
Re: Top-End Redo
24 Aug 2019 12:05
#809757
MTC 1135 piston kit has been ordered, and the cylinder block shipped-out to Pit Stop Performance. :woohoo:
Joe recommended having .120" taken off the piston domes to reduce cranking pressure, but he did not mention what effect that will have on the advertised 10.5:1 compression ratio.
Would anyone care to suggest what the resulting compression ratio might be, and what difference it will make for the engine size?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Top-End Redo
24 Aug 2019 12:46
#809762
Why take off .120" on the piston domes? A cyl. spacer do the same effect much cheaper and you can go back if needed.
The following user(s) said Thank You: daveo, SWest
