1992 Kz1000P Sticky black Goo on spark plugs
Re: 1992 Kz1000P Sticky black Goo on spark plugs
28 Sep 2015 14:32
Your manual will tell you this and I'll add one thing. Don't bend the tabs so they make the needle sit crooked.
- hardworkinpd
29 Sep 2015 07:35
Ok, I got the tank and carbs on the bench *close* to the way they will be sitting on the bike.
Now to wrestling with the "Tube" Test*! Bending the float tangs so the are Flat is going to be a challenge!
Adios, Kip
Adios, Kip
- jackleberry
29 Sep 2015 08:16 - 29 Sep 2015 08:18hardworkinpd wrote: Ok Jack I'm going to try and get the gas tank and carbs as close together as I can. What would you say could be the Maxium distance and hieght I could have between the Fuel Tap and the carbs to do the Tube Test and setting the float hieght.
Also when I get to that point how will I know how many mm I should adjust the float tang as compared to the tube reading?
You guys have been a Great help, Thanks! Kip
As close as you can get it to the distance it'll be above the carbs when installed on the bike, which is probably 4 or 5 inches... It doesn't have to hover directly above the carbs (that is, it doesn't matter how long the hose is), but it should be at the same level above them that it would be when installed.
As for the relationship to float height and fuel height, I'm afraid it's just an iterative try/fail process. I would start with 19mm from the gasket to the float measurement point, measure the fuel level, and tweak from there. If the fuel level is too high, you have to increase the float height. Try 1mm. If that lowers the fuel level too much, then go .5mm back the other way. If that gets them all within 2mm to 4mm of the seam on the fuel measurement, then you're good. If you're really concerned about leaking, aim for 4mm. (that's what I set mine to and I've not had any leanness/starvation issues).
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
Last edit: 29 Sep 2015 08:18 by jackleberry.
- hardworkinpd
29 Sep 2015 09:48 - 29 Sep 2015 09:49
Hey Jack do I take the tube test measurement from the *Very Top* edge of the *float bowl*?
Thanks, Kip
Thanks, Kip
Last edit: 29 Sep 2015 09:49 by hardworkinpd.
29 Sep 2015 09:53
Here's how it's done on the Mikuni VM carbs (and probably most or all other carbs). Ed
Attachment ClearTubeTest-3.jpg not found
- hardworkinpd
29 Sep 2015 10:10 - 29 Sep 2015 10:11
As per the drawing you start the measurement from the carb body where the over hang starts over the float bowl down?
Thanks, Kip
Thanks, Kip
Last edit: 29 Sep 2015 10:11 by hardworkinpd.
29 Sep 2015 10:18
Yes. You measure from the joint where the bowl and carb body meet down to the top of the fuel in the clear tube. Ed
- hardworkinpd
29 Sep 2015 10:28
Ok, I will start the measurement at the very point where the carb body *meets* the float bowl.
Thanks Ed!
Adios, Kip
Thanks Ed!
Adios, Kip
- jackleberry
29 Sep 2015 10:54hardworkinpd wrote: Ok, I will start the measurement at the very point where the carb body *meets* the float bowl.
Thanks Ed!
Adios, Kip
I use a 2mm zip-tie around the hose as my zero point. There's a little ledge where the gasket meets the carb body which the zip tie can be pushed up against. Blocks the view a bit but anything less than 2mm is too high anyway.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- hardworkinpd
29 Sep 2015 14:22
Ok, looking at the outside of the float bowls. From the very top of it where it makes contact with the gasket that mats to the carb body is like a casting seam. That seam is pretty darn close to 4mm from the very top of the float bowl.
I *Hope* that is correct.
If so adjusting the floats like Jack recommended, setting them off the gasket to 19mm, the tube test is showing me pretty close to 4mm across all 4 carbs.
Gosh I hope I did this right AND also I hope when I go back out to the garage the carbs aren't leaking.
Adios, Kip
Adios, Kip
- jackleberry
29 Sep 2015 18:08hardworkinpd wrote: Ok, looking at the outside of the float bowls. From the very top of it where it makes contact with the gasket that mats to the carb body is like a casting seam. That seam is pretty darn close to 4mm from the very top of the float bowl.
Adios, Kip
Sounds good.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- hardworkinpd
30 Sep 2015 04:51
Well I should be excited in anticipation of completing this phase of getting my bike running, but to be honest I'm scared that something ain't gonna work.
You know, joining the military, being able to eat chili that burn the inside of your mouth worse than drinking battery acid, drinking Irish whiskey, having your prostate checked and changing baby diapers will *Make A Man Out Of You*. Well I'm going to add owning a vehicle with multipule carburators to that list!
Start to put the carbs back on today!
Adio, Kip
Adio, Kip
