It runs!!!! BUT!
- loudhvx
Re: Re:STILL NEED HELP! WONT START!
07 May 2015 05:20
Great job!
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bromz
- 1981 kz1000 csr
07 May 2015 07:49
Thanks guys I will post a vid once I sync them.
- bromz
- 1981 kz1000 csr
Re: STILL NEED HELP! WONT START!
07 May 2015 15:06 - 07 May 2015 15:07
Ok rode it around town tonight. Got te idle set well. When I get time later tonight I will sync them. Had good torque. Kept it under 3k Rpms. Never went over 50mph. Prob went a total of 15 miles.
Last edit: 07 May 2015 15:07 by bromz.
07 May 2015 15:11
Don't go over 4000 RPM in 500 miles. Shift up and down using the power and for breaking. Don't baby it but don't thrash it ether. After 500 miles, ride the piss out of it. :woohoo:
- bromz
- 1981 kz1000 csr
- bromz
- 1981 kz1000 csr
Re: Re:It runs!!!!
09 May 2015 14:24
Rode it about 20 miles today! Rode fine. Came home dumped the oil and gonna sync carbs today or tomorrow. It's coming together.
- bromz
- 1981 kz1000 csr
Re: Re:It runs!!!! BUT!
19 May 2015 20:39
Well I have smoke coming out of my left pipe so I figure 1 or 2 cylinder is leaking oil. 150 psi comp all the way across. So I would say rings and valve seats are good. So did I blow a valve stem seal? I also have oil blow out of the left reed vlv.
Any ideas before I pull the head? Also I have about 300 miles since rebuild and number 2 cylinder plug gets black after a short ride. All others are nice and tan. I have a total of about 300 miles on it now.
Attachment ImageUploadedByTapatalk1432092506.510249.jpg not found
- bromz
- 1981 kz1000 csr
Re: Oil smoke out the left tail pipe
20 May 2015 05:07 - 20 May 2015 05:43
Oil soaked #2 plug. Oil out of the air valve on left side. Excess carbon on #2 exhaust valve. 150 psi across all 4 cylinders. What am I missing? Valve stem seals looked ok.
Last edit: 20 May 2015 05:43 by bromz.
- bromz
- 1981 kz1000 csr
Re: Re:Oil out the left tail pipe
20 May 2015 05:32Attachment ImageUploadedByTapatalk1432124596.185823.jpg not found
- KZQ
- Administrator
20 May 2015 06:02
Does the smoke abate after a few minutes of running?
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- 80B4
Re: It runs!!!! BUT!
20 May 2015 06:20
I would look at the carb for that cylinder before pulling the head. You have good compression accross all 4 cylinders. Check the cheep / easy things first.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
20 May 2015 06:26
Yeah, you might be washing out the rings. One carb may be flooding. It could clear up if corrected.
300 miles isn't a lot.
