Valve Noise/No compression
  • LarryC
  • LarryC's Avatar
Re: Valve Noise/No compression
14 Apr 2014 18:42 - 14 Apr 2014 18:43
#629040
BIGKEVIN wrote: I cant use the spark plugs because with the Dyna S connected, I don't have any voltage to the coils. I have the coil mod done and I am getting power to the Dyna S via the #87 connector on the relay. Whenever the Dyna S is installed, I lose power to the Dyna S and the coils. Something, possible the Dyna S itself is causing a loss of voltage to the coils and the Dyna S. I have it wired up the way the directions explain and checking timing according to the directions that say timing procedure. Trying to figure out why I am losing voltage when the Dyna S is slipped over the rotor ?
Kevin,
I have been very patient.....right up until I read this..... GET THAT SHIT OFF YOUR BIKE! :laugh: And by SHIT...I'm not talking about the Dyna ignition........
Larry C.
Last edit: 14 Apr 2014 18:43 by LarryC.
  • BIGKEVIN
  • BIGKEVIN's Avatar Topic Author
15 Apr 2014 05:00
#629080
Are you talking about the coil mod ? If not, what are you talking about ? I am new to these old bikes, so I am sorry about all of the quetions.
1976 KZ900
2006 ZX6R
  • LarryC
  • LarryC's Avatar
15 Apr 2014 19:07
#629178
Yes. Dump that coil mod bullshit. Fix your wiring issues if your primary coil voltage is low. Anything less is just a band aid.
Start by cleaning the bullet connections and multi pin connections. Take your switches off and clean them with contact cleaner. Once you get the connections sorted, the voltage will be correct.
There are two ways to do things. The RIGHT way and the WRONG way....Nothing in between B)
Larry C.
15 Apr 2014 19:15
#629181
This stuff cleans electrical contacts well. Ed
Attachment DEOXIT.jpg not found
The following user(s) said Thank You: LarryC
  • BIGKEVIN
16 Apr 2014 07:49
#629212
LarryC, will start checking/cleaning connections.
650ed, just picked up some of the contact cleaner also.
1976 KZ900
2006 ZX6R
  • BIGKEVIN
28 Apr 2014 15:56
#630737
I got everything put back together after finding a wire that was shortening out, causing no power to the coils. I cleaned the cards and did the bench sync on them. I have 140 psi, 140 psi, 130 psi and 125 psi when doing a compression check with the engine cold and throttle held wide open. I tried doing the running sync with my Motion Pro, but the #3 carb sucks all of the fluid out of the tool. I was able to get the other 3 carbs in sync. What would cause the fluid to get sucked out of the tool ? Thanks to all who have helped in getting the bike running again.
1976 KZ900
2006 ZX6R
  • BIGKEVIN
28 Apr 2014 15:59
#630738
The air screws have not been touched since the carbs were cleaned. They are still about 1 and 1/4 turns out.
1976 KZ900
2006 ZX6R
  • BIGKEVIN
06 May 2014 17:12
#631572
Any ideas on what is causing the fluid to be sucked out of the sync tool only on 1 card ? Any help/assistance would be appreciated.
1976 KZ900
2006 ZX6R
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
06 May 2014 17:17 - 06 May 2014 17:32
#631573
BIGKEVIN wrote: Any ideas on what is causing the fluid to be sucked out of the sync tool only on 1 card ? Any help/assistance would be appreciated.
Are you able to do the initial setup to get the fluid level aligned about a third of the way up? :blink:
P.S. If you haven't already done so, contact Motion Pro. They were very helpful when I first got my sync-tool. I believe the phone number was printed on the instruction sheet. B)
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 06 May 2014 17:32 by daveo.
  • BIGKEVIN
06 May 2014 17:34
#631575
I don't remember seeing anything about an initial setup. I bench synced the carbs and I am able to get carb 1,2, and 4 about 1/3 of the way up the tube.
1976 KZ900
2006 ZX6R
