turbo time....
- Lorcan
- Speed Loony
Re: turbo time....
10 Feb 2013 06:04donthaveakawman wrote: wouldn't that just pump fuel back into the tank?
That's quite a sensible question for you. The fuel is also pressurised. On a carb system the carbs are pressurised by boost and so is the fuel supply. On a fuel injection system an electric pump provides the fuel at a constant pressure above boost pressure.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- donthaveakawman
- donthaveakawman
- NakedFun
Re: turbo time....
10 Feb 2013 13:20
To resolve all these issues, you could just do a draw through system by having a larger, single carb and place it on the inlet side of the carb. Blow through carbs on the other hand have a few perks, but require a few modifications to essentially pressurize the carbs completely which includes vents. This way the carb still "sees" the pressure differential across the carb and pull the fuel from the bowl.
Don,
To answer your question, on a naturally aspirated engine, air speed is crucial to keep the fuel atomized in the charge by keeping the charge fast enough so the fuel droplets don't drop out. It is also crucial to cylinder filling at low engine speeds. You put larger carbs on a na motor, you typically lose low speed torque but gain top end power. Now due to a turbo forcing air into the engine, the charger is supply the velocity, so you don't need the smaller carbs provide this via a reduced cross sectional area. Now you want the largest, properly sized, carb so you don't allow the carb to become a critical flow choke point.
Cory
Don,
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- wireman
Re: turbo time....
10 Feb 2013 14:01Yeah I know,hes scaring me! :laugh:Lorcan wrote:donthaveakawman wrote: wouldn't that just pump fuel back into the tank?
- Lorcan
- Speed Loony
Re: turbo time....
10 Feb 2013 14:37
I'm sure it's only temporary :laugh:
760cc - 8.69@162mph
- lushbaugh
- everybodys a pro......
Re: turbo time....
10 Feb 2013 21:24
hahaha you guys answered all the questions and stole my thunder lol. but yes that sums it up. and im using one flatside carb. hsr 42. and draw thru method.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- donthaveakawman
Re: turbo time....
10 Feb 2013 21:57 - 10 Feb 2013 21:57
42? if you started with4 29's wouldn't that be going backwards? carter afb or a quadrajet would be my best suggestion. :woohoo:
Last edit: 10 Feb 2013 21:57 by donthaveakawman.
- wireman
Re: turbo time....
10 Feb 2013 22:03 - 10 Feb 2013 22:04
[attachment:1]C:\fakepath\handface.gif[/attachment]
:woohoo: :woohoo:
:woohoo: :woohoo:
Last edit: 10 Feb 2013 22:04 by wireman.
- lushbaugh
Re: turbo time....
11 Feb 2013 03:33
not a snowballs chance in hell. holley double pumper.....
- donthaveakawman
Re: turbo time....
12 Feb 2013 21:19
you may be able to find a similar bore throttle setup/fuel injection from a newer cycle.
- lushbaugh
Re: turbo time....
13 Feb 2013 15:35donthaveakawman wrote: you may be able to find a similar bore throttle setup/fuel injection from a newer cycle.
no thanks, tried and true hsr 42 draw thru
