turbo time....
- 4TheKZ1000
Re: turbo time....
03 Jan 2013 15:01Lorcan wrote: 20 elephant...
:laugh:
What does "20 Elephant" mean?
20 psi boost
200 mph or kph
:huh:
- DoubleDub
- zukdave
Re: turbo time....
03 Jan 2013 23:56lushbaugh wrote: do it.
I just might hell its only a couple grand more right ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- lushbaugh
- everybodys a pro......
Re: turbo time....
04 Jan 2013 15:23
depends on how crafty you are and what you already have done, im not sure on the gpz 750 motors
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- zukdave
Re: turbo time....
04 Jan 2013 22:11Started with this.lushbaugh wrote: depends on how crafty you
Little time and less then two grand it's knockin on the 11's.
Ya I got crafty down pat.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- lushbaugh
Re: turbo time....
06 Jan 2013 19:05
what bar are you using dave?
- zukdave
Re: turbo time....
06 Jan 2013 21:46
Its a zukiworks home edition.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 4TheKZ1000
Re: turbo time....
06 Jan 2013 21:52
Damm Dave, you really turned that bike around....gr8 job on WE-bars also.
- wireman
Re: turbo time....
06 Jan 2013 23:49:woohoo: :woohoo: :woohoo: :woohoo: :woohoo:zukdave wrote: Its a zukiworks home edition.
- lushbaugh
Re: turbo time....
07 Jan 2013 01:16
hahahaha i love it
- NakedFun
Re: turbo time....
05 Feb 2013 17:16lushbaugh wrote: ....cory what are your thoughts on the numbers you came up with in regards of the setup and what size exhaust primarys?
Lush,
Sorry I missed this within the paragraph! I think your combo appears to good for power, but the main thing is collector turbulence is one watch out. Having equal length runner that collect at one point right at the collector. As far as runner diameter, it will depend on what you find in testing, but I would start out with a header diameter of at least 80% of exhaust port outlet diameter. I figure you are going to mount it right behind the front tire, and due to the short length of that header design, exhaust gas velocity will easily maintained, so I would not worry about going to tubing ID that matched port outlet diameter. Maintaining exhaust gas velocity via reducing header ID would not be a problem with this configuration.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- NakedFun
Re: turbo time....
07 Feb 2013 16:45
I went ahead and mapped out your breathing lines on the HX25 compressor I have and came up with a better match than anticipated. It is a little big like we figured, but you start getting into the boost prior to 3000 RPM.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
