turbo time....
- lushbaugh
- everybodys a pro......
Re: turbo time....
08 Feb 2013 01:53
im no expert but i see this as a very good mapping. i like where the boost comes in because ill have plenty of room to grow in cc's without changing alot and its still very usable. lmk whats going on and we can work something out for that turbo.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- donthaveakawman
- NakedFun
Re: turbo time....
08 Feb 2013 11:30
Lush,
I keep you informed. If it doesn't sell by Monday, you and I will do some swapping for those VM28's.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- lushbaugh
Re: turbo time....
08 Feb 2013 19:53
cool man and what dyno sheet do you want? at the end of the build ill post one.
- donthaveakawman
Re: turbo time....
08 Feb 2013 21:54
look at the dynojet dyno location list. my local shop that has one quoted me 60-100$ for testing.
- wireman
Re: turbo time....
09 Feb 2013 21:37
While Im waiting for a yellow frame to show up at my door I finished making a few of the gussets for it today .
I didn't have the swing arm pivot braces or the down tube that go in front of motor in the pictures,but you get the idea
- wireman
Re: turbo time....
09 Feb 2013 21:37
- donthaveakawman
Re: turbo time....
10 Feb 2013 00:31
so the basic principal of the turbocharger is to get more air and fuel into an engine. wouldn't it be better if they would have made the bigger engines with larger carburetors? example- 36mm carbs for a gpz750 and 26mm carbs for a 1000?
- 4TheKZ1000
- wireman
Re: turbo time....
10 Feb 2013 00:47That would be the difference between consentual horsepower and force fed horsepower,a motor will only draw in so much air/fuel without a little assistancedonthaveakawman wrote: so the basic principal of the turbocharger is to get more air and fuel into an engine. wouldn't it be better if they would have made the bigger engines with larger carburetors? example- 36mm carbs for a gpz750 and 26mm carbs for a 1000?
The following user(s) said Thank You: donthaveakawman
- donthaveakawman
- wireman
Re: turbo time....
10 Feb 2013 03:25 - 10 Feb 2013 03:26
[attachment:1]C:\fakepath\frypan.gif[/attachment]
:laugh:
:laugh:
Last edit: 10 Feb 2013 03:26 by wireman.
