kz750 twin performance upgrades
- bountyhunter
Re: kz750 twin performance upgrades
23 Aug 2012 03:45Actually, the original spec for the 750 twin is .002" - .004" but was later "opened" to .002" to .006".gumby prichard wrote: but .0019inches converts to .05mm so basically .002 is hardly in spec, which would mean i need to replace the shims anyway with smaller ones....correct?
Technically, .002" is in spec but I shoot for .003 - .005" on mine
- bountyhunter
23 Aug 2012 03:47These are 32 mm shims and they are not available new from anybody. Z1 Enterprises has some sizes available in used shims. Other than that, ebay has a few sometimes and some dealers will swap one with $ on the side.gumby prichard wrote: can i find these shims at advanced auto? and pleaces liek that? or should i go straight to kaw?
- gumby prichard
23 Aug 2012 11:57
oh great that makes me feel great about this. so do you think they couldnt find the correct size they needed so they threw in some larger ones?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
23 Aug 2012 15:29
lets say i wanted to go with bucket over shim, what bike could i steal from that would fit?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- bountyhunter
23 Aug 2012 15:59No, clearances gradually get tighter over time. The previous owner probably never checked them. The service interval for checking clearance is 3000 miles.gumby prichard wrote: oh great that makes me feel great about this. so do you think they couldnt find the correct size they needed so they threw in some larger ones?
- steell
23 Aug 2012 16:59 - 23 Aug 2012 17:00gumby prichard wrote: lets say i wanted to go with bucket over shim, what bike could i steal from that would fit?
Aftermarket buckets from APE, bore the 8 holes to fit the buckets, send an original retainer to APE and ask them to make you some titanium retainers for 9.48mm shims (lots of bikes use that size, so they are easy to find) for shim under bucket, assemble head with shim under bucket.
Last edit: 23 Aug 2012 17:00 by steell.
- gumby prichard
23 Aug 2012 17:31
so none that drop straight in? gotta bore? lame. sounds like more work than i really want to do. i'll stick with shim over bucket. Thanks again guys for being so attentive.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
23 Aug 2012 17:36bountyhunter wrote:No, clearances gradually get tighter over time. The previous owner probably never checked them. The service interval for checking clearance is 3000 miles.gumby prichard wrote: oh great that makes me feel great about this. so do you think they couldnt find the correct size they needed so they threw in some larger ones?
ahhhhh, i've never owned dohc im used to rockers and for some reason i was thinking the lobes and shims wear down causing you to have to put larger shims in. :S
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
02 Sep 2012 05:44
OK GUYS hopefully i can get some clarity in this.
checked the shims, exhaust 1 shim was 150, exhaust 2 shim was 165, bot intake were 160, any idea why the two exhaust valves would have .15 difference?????? also either way a .002 feeler gauge would not fit in any of the valve clearances...... suggestions about the whole situation? and what shim should i move to? should the exhaust shims not match?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
02 Sep 2012 05:48
actually it may have been 250 265 and 260s ,but you know what i mean.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
02 Sep 2012 11:43 - 02 Sep 2012 11:43
Typically, valve heads gradually sink deeper into their seats inside the engine head, thereby requiring periodic replacement with gradually thinner shims in order to maintain valve clearance within specs.
Such routine shim replacement usually continues until the thinnest available shim won't provide the needed clearance.
When the thinnest available shim won't provide the needed clearance, it may be feasible to "tip" the valve, which is a precise process -- not for the do it yourselfer -- whereby a minute portion of the stem end of the valve is machined or ground away in order to achieve a "shorter" valve stem, which thereby adds clearance.
After "tipping," it is of course necessary to determine and install the newly required shim size.
Last edit: 02 Sep 2012 11:43 by Patton.
- gumby prichard
02 Sep 2012 13:45
yeah, i know that, but does it make sense that the exhaust valves are two completely different sizes?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
