- Thank you received: 1
kz750 twin performance upgrades
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- bountyhunter
- Thank you received: 337
Yes. The shim size is dictated by how far the had to cut the valve seats to get them right.gumby prichard wrote: yeah, i know that, but does it make sense that the exhaust valves are two completely different sizes?
NO. You must use the shim that gives the correct clearance.and also if not, should i just make both exhaust valves equal sized shims?
- tinlizzie37
Bob KZ 650 E1, En 450
- gumby prichard
tinlizzie37 wrote: It looks to me you have pods on and they're not connected to the box. Your in for a lot of guessing of carb jets, with open pipes and pods. The carburation is messed up as it sits. Check the point gap and timing also. You may have dirty carbs also. Bob
that is not my bike. i was using it as an example of what my bike was doing. i run completely stock. but i believe the problem is the valves are out of spec.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Nebr_Rex
- Thank you received: 300
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
apparently if i move to a 140, 155, 150, 150 it will give me a clearance of .005 which is supposedly just out of spec..(.002-.004) but i have read most people suggest moving to .005 stating a measurment that small won't make a difference, and it will give you a longer period before changing your shims again.
can this be confirmed?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- KZQ
- Administrator
- Thank you received: 1415
Keep in mind a wider gap runs noisier.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- Motor Head
- Thank you received: 391
Then here is also the shim chart: www.kzrider.com/filebase/doc_download/107-valve-lash-chart-02
Now if you can turn the Cam Follower/ Bucket with your finger, but can't get a .002" feeler gauge in there, go Down two shim sizes. If you get .005" of clearance that will quickly change again when run for a few hundred miles, as there is most likely some carbon on the face of the valve from leaking.
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- bountyhunter
I target a range of .003" - .005" on mine just because a slightly wide clearance won't kill anything but a tight one can burn a valve seat.gumby prichard wrote: ok guys, so i went to this site and calculated my proper shim replacement size. www.maultechatv.com/techguides/Valve%20C...Calculator/index.php
