kz750 twin performance upgrades
  • gumby prichard
  • gumby prichard's Avatar Topic Author
18 Aug 2012 01:34
#543215
sooo, rode my kz750 twin for the first time, rides super smooth, but honestly im quite disappointed in the low end power. I really feel like it doesn't have anymore low end torque than my kz400. is there anything i can upgrade that wouldn't be a dramatic change? Or do you think i could just be losing power, maybe it's not running correctly, i mean it does idle quite weird and i have messed with the ignition timing. it will idle in triplets, like burrum dum dum burr um dum dum. I feel stupid using onomatopoeia to describe the sound of my bike lol, but i think you get it, it almost idles like a two stroke does. I also am not too fond of this gravity feed i have any cheep upgrades available
[img]http://https://instagr.am/p/OcKDfiqkv_/media/?size=l[/img]?
thanks guys
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • bountyhunter
  • bountyhunter's Avatar
Re: kz750 twin performance upgrades
18 Aug 2012 01:38
#543217
gumby prichard wrote: sooo, rode my kz750 twin for the first time, rides super smooth, but honestly im quite disappointed in the low end power. I really feel like it doesn't have anymore low end torque than my kz400. is there anything i can upgrade that wouldn't be a dramatic change?
Find a set of stock pipes with the crossover. Mine used to pull like a freight train from 2000 RPM up with the original pipes.
The following user(s) said Thank You: gumby prichard
  • gumby prichard
18 Aug 2012 02:19
#543226
you mean cross over as in 2 into 1? cause that's what i have. AND THAT MAKES ME HAPPY THAT MEANS THERE'S HOPE! but right now idk what's going on, maybe it's just running on one cyl. but both pipes are hot as hell. Like i said idles weird and occasionally backfires when revved, any videos on changing the valves on these DOHC? they confuse me with no rockers!
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • Del_Herring
  • Del_Herring's Avatar
18 Aug 2012 02:20
#543227
I would think bottom end is what the twins would be best at. If it's your first time with it, might be worth going through and syncing the carbs, checking plugs to make sure your mixture is right, and the like.
Crossover is where it's 2 into 2, but there's a connector between the two.
1983 KZ750-N2 Spectre
  • gumby prichard
18 Aug 2012 02:20
#543228
i meant checking(clearance) the valves not changing. :silly: :huh:
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • Del_Herring
18 Aug 2012 02:21
#543229
If you think it's running maybe on just one. Let it cool completely. Where you can grab the engine and pipes. Then start it up, and check how hot the two pipes are getting coming out of the head. They'll be notably different if one isn't firing.
  • gumby prichard
18 Aug 2012 02:23
#543230
but wouldnt you get better airflow with a 2 into 1? being that they meet at an angle which both tubes are being forced in the same directing rather than having to turn at a right angle? idk maybe not
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • gumby prichard
18 Aug 2012 02:24
#543231
no, they were both scortching. that thing heats up in a matter of seconds
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • gumby prichard
18 Aug 2012 02:47
#543236
oh i guess i should give my set up too, currently have and want to keep stock airbox, maybe k&n filter, 2 into pipe with stock exhaust.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
18 Aug 2012 07:15
#543241
Other possible reasons for weak pull-away could include issues with carb (such as air leak, non-sync or incorrect pilot mixture), or issue with ignition timing, or with functioning of the timing advancer.
Good Fortune! :)
  • gumby prichard
18 Aug 2012 12:15
#543258
where is the timing advancer located? or is that the round plate with the point on it? and is ther ea certain way to sync gravity feed carbs?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
  • Nebr_Rex
  • Nebr_Rex's Avatar
18 Aug 2012 13:58
#543268
gumby prichard wrote: where is the timing advancer located? or is that the round plate with the point on it? and is ther ea certain way to sync gravity feed carbs?
Time to buy a manual.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
