- Thank you received: 1
kz750 twin performance upgrades
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- bountyhunter
- Thank you received: 337
Don't think that has anything to do with spark plug heat range.KZJOE900 wrote: Would the introduction of unleaded gas have been a factor?
reference
Influences to spark plug temperature
Any of the following situations can increase spark plug temperature:
-Lean air/fuel mixtures
-Increasing compression
-Forced induction (Supercharging, turbocharging or Nitrous)
-Camshaft change
-Advancing ignition timing
-Higher engine speed
-Higher engine load
-Lower air temperature (more dense air resulting in leaner air/fuel mixture)
-Lower humidity (more dense air resulting in leaner air/fuel mixture)
www.totalmotorcycle.com/maintenance/sparkplugs.htm
- bountyhunter
But the service manuals for the 750 twins in that series (B3) and my '79 (B4) call out the hotter B6ES plug. If the engine is tweaked up for more power, that would imply colder plug if anything. If the later years make less power (probably from the smaller 34 mm carbs) they could run a hotter plug.gumby prichard wrote: my 78 has 4 more HP :pinch:
According to the OEM part drawings, it calls out B6ES for the B3/B4 models (see below) and the B8ES is listed as optional.
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- bountyhunter
My '79 printed manual showed 55 HP and B6ES plugs.gumby prichard wrote: but my 78 specs noted the bike at 55 hp so if your bike is a 79, stting that they have more power would be incorrect because the specs you posted showed 51 hp, NO? :huh: :huh: :huh: :huh: :huh: :S
This manual I got on a CD ROM also shows 55 HP for US models, the 51 HP is the "G" which is the German model. They have to make all the German vehicles less powerful so they can't be used to invade Poland. :laugh:
- gumby prichard
No but honestly me and my friend always blame ever stripped bolt or rusted shut piece on any bike we buy on ww2, "ever since then they are seeking vengence by screwing us over with their designs and selling them too us" lol :lol: :lol:
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
CAN ANYONE TELL ME WHAT THIS IS OFF OF MAYBE AND WOULD THIS CAUSE ANY SORT OF IGNITION TIMING OR SPARK PROBLEM CAUSING MY TIMING TO BE INCORRECT?!
on a side note i ordered the dyna s ignition today along with my right side calipers to complete my dual disc setup :laugh:
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Motor Head
- Thank you received: 391
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- steell
Maybe you have four cylinder plug wires, A four cylinder coil will fire 1 & 4 or 2 & 3.
Measure between the two spark plug wires and look for 17k - 23k ohms with plug caps removed.
If you have the hard plastic plug caps they're probably 5k ohms each.
