kz750 twin performance upgrades
- gumby prichard
Re: kz750 twin performance upgrades
21 Aug 2012 17:58
why yes, i just cleaned the petcock by shooting carb cleaner through all the holes and ports, also installed petcock rebuild kit. cleaned it quite well, also i have have fuel filters on both fuel entrance ports, or whatever you wanna call them, now these are lawnmower fuel filters. idk if that matters..... but thet are new and look almost just like ones you put on a two stroke dirtbike.
i also atempted to clean the tank out with behr concrete etcher, it worked well but flash rusted almost back to where it was in the first place. i am thinking about just "creme"ing it.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
21 Aug 2012 18:29
also,i checked both plugs on the number 1 cyl where the first plug fouled and was not running and the good plug had plenty of spark, i also tested both plugs on the other wire and the same occured. so it seemed one cyl was firing and just the plug was bad or too badly fouled.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- bountyhunter
21 Aug 2012 19:04The rust sediment was what was clogging up my carbs. I finally lined it with the Kreem stuff.gumby prichard wrote: i also atempted to clean the tank out with behr concrete etcher, it worked well but flash rusted almost back to where it was in the first place. i am thinking about just "creme"ing it.
- gumby prichard
22 Aug 2012 02:19
yeah that was my next step to tank prep. i guess i'm going to go ahead and check the valve clearance to be sure, then if valves are in spec i will next go ahead and kreem the tank. if not the valves while kreeming the tank i will also replace the coils put brand new points on and a condenser. i dont see what else could be causing the problem...oh yeah i'm putting a supertrapp muffler on it.
question. is there an electronic ignition available for this? or are there any off maybe like a gpz that is compatible?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- bountyhunter
22 Aug 2012 16:01I believe the Kawi electronic ign from the 440 twin will work, and it's a good unit.gumby prichard wrote: yeah that was my next step to tank prep. i guess i'm going to go ahead and check the valve clearance to be sure, then if valves are in spec i will next go ahead and kreem the tank. if not the valves while kreeming the tank i will also replace the coils put brand new points on and a condenser. i dont see what else could be causing the problem...oh yeah i'm putting a supertrapp muffler on it.
- gumby prichard
22 Aug 2012 18:39
oh you guys are wonderful. getting rid of that point system would be a dream! :lol: :laugh: :laugh:
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
22 Aug 2012 19:14
you mean the kz440? correct? cause all i could find is point systems for them. what about a en450? aka ltd 454?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
23 Aug 2012 00:46 - 23 Aug 2012 01:01
ok guys so tonight i took off my valve cover, turned engine so that camshaft lobes were pointing away from the valve buckets, my feeler gauge went as low as .002 inches so i tried it last and it would not fit, obviously along with the .003 and .004. looks like correct valve timing is .05mm-.10mm
so .08mm converts to .0031 inches, this means somehow the shims in my bike are too large. correct?
if so how does this happen? Is it that the valves are wearing down against the seat? Also how do i know what size shims i need?
i am also EXTREMELY excited to announce my valves are shim over bucket. so i guess they didnt do bucket over shim until later models than the b4.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 23 Aug 2012 01:01 by gumby prichard.
- bountyhunter
23 Aug 2012 01:54 - 23 Aug 2012 01:54
You can get feeler gauges as small as .001" (I have a set that goes that low).
If the bucket turns easily, there probably is some clearance. If an .002" shim won't go under, but the bucket is loose, the clearance is between .000 and .002"
Last edit: 23 Aug 2012 01:54 by bountyhunter.
- gumby prichard
23 Aug 2012 02:27
but .0019inches converts to .05mm so basically .002 is hardly in spec, which would mean i need to replace the shims anyway with smaller ones....correct? and can i find these shims at advanced auto? and pleaces liek that? or should i go straight to kaw?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- mtbspeedfreak
23 Aug 2012 02:29gumby prichard wrote: but .0019inches converts to .05mm so basically .002 is hardly in spec, which would mean i need to replace the shims anyway with smaller ones....correct? and can i find these shims at advanced auto? and pleaces liek that? or should i go straight to kaw?
Z1 Enterprises
2000 ZRX 1100
1976 KZ 900- Daily Driver
- gumby prichard
23 Aug 2012 02:29
i had my caliper with me and everything idk why i didnt check the size of the shim.....oh wait i didnt have the adjuster to compress the valves....
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
