- Thank you received: 18
bore kit
- andy9802gt
- If it tastes that good, eat it yourself.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- z1kzonly
- Thank you received: 540
Put a heavy duty main bearing plate cap on it.
Your good to go
- larrycavan
- Visitor
ok so would the bottom end take a 1105 kit with 10.25:1 compression or not
I'd shy away from 1105 kit and go either 1075 or bite the bullet and go 1197. 1105 will work but the sleeves are getting too thin IMO for a sound, long lasting street motor.
If you're talking about needing the crank welded, I'll say this. If it's a good, KZ 1000 crank and you're not going to put a slick and wheelie bar on it, you don't need to weld it.
On the other hand, If I'm spending the money for a totally fresh top end, the cases are coming apart and everything is getting inspected plus a new cam chain.
Never toss big money into a 30 year old motor unless you have inspected it completely
JMO.... other's will surely feel contrary or give you reasons why they would. I'm not here to argue logic, only offer you suggestions that are based on a lot of years with these old KZ's
Just don' waste your money on BS34 carburetors and you'll probably be just fine :woohoo:
- DoubleDub
- Visitor
DoubleDub wrote:
andy9802gt wrote:
Popular opinion is it takes a 10.25:1 1075, ported head, and your choice of aftermarket carbs to make 130- 150 hp at the crank which is about 110- 120 at the wheel. If you want things to be bulletproof then you have to weld the crank and back cut the tranny and put in studs. Hell I just want to give the young guys fits stop light to stop light on their "race bikes"
FWIW, it costs a lot of nickels and dimes to get 150 horsepower. Going quick isn't cheap.
Hmm...more optimistic than I've seen, but I'll defer to the more experienced. Not my realm of expertise!
It's called being realistic and he's right on the money.
Like I said...I defer.
- PLUMMEN
- Thank you received: 104
yeah but if its allready apart why not spend $75 and have the crank done,then you never need to get back in there again if you decide you want to hotrod it down the road.kzgeary wrote:
- larrycavan
- Visitor
I would agree, IF it's torn down, but the price is likely to be closer to $200 - $250 if it's got to be shipped out.
1000 cranks used to hold up to mild street builds like that. But there's been a lot of water over the dam since those days Jim.
- PLUMMEN
with all those years of twisting wire nuts my right wrist sometimes sticks in wide open position(arthritis ya know! :woohoo: ),google my dmv record sometime! :blush: :woohoo:
as crazy as people seem to be about these 180 radial tires these days,thats a lot of rubber to hook up whether its a slick or or not.
- andy9802gt
I just paid $475 for mine to be completey torn down, cleaned, shot peened, honed the big and little ends, replaced the #5 thrust with roller bearing, indexed, welded, and trued. I hope it never breaks 'cuz I want to go 1197 in a year or two.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- kzgeary
- PLUMMEN
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- Old Man Rock
- Thank you received: 225
Hell if I can run mine in AZ heat, so can you...
NOTE: Stop and go traffic, well hell not going to help but if your moving.... NICE!
Need one of these then....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
