- Thank you received: 104
bore kit
- PLUMMEN
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
1979 kz 1000 06 katana 750
- PLUMMEN
- PLUMMEN
- kzgeary
- PLUMMEN
1075 would probably make as much power with stock sleeves since the bore has better chance of staying round due to more meat left in the sleeves.would a 1105 kit with 10.25:1 compression be ok on a stock bottom end. it said it didnt need crankcase clean up
id still go though bottem end and weld crank,new timing chain etc......
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- larrycavan
- Visitor
andy9802gt wrote:
Popular opinion is it takes a 10.25:1 1075, ported head, and your choice of aftermarket carbs to make 130- 150 hp at the crank which is about 110- 120 at the wheel. If you want things to be bulletproof then you have to weld the crank and back cut the tranny and put in studs. Hell I just want to give the young guys fits stop light to stop light on their "race bikes"
FWIW, it costs a lot of nickels and dimes to get 150 horsepower. Going quick isn't cheap.
Hmm...more optimistic than I've seen, but I'll defer to the more experienced. Not my realm of expertise!
It's called being realistic and he's right on the money.
- larrycavan
- Visitor
wanting to do a 1075 bore kit with 12:1 compression. would it be wise to do that on a stock bottom end, and would the engine hold that much compression.
Getting down to the original question...
You can't run compression that high on pump gas.
If you want a good strong KZ without a second mortgage, then here's a great all around package to do that.
1075cc 10.25:1 Piston Kit
88CFM head
CRS29 or RS34 Carbs [depends on a few things]
There are several good cam grinds to use. Each has their own distinct advantages. Some would be
Web 118 - Great little all around cam. Shim on Top
APE K410 - More upper mid range punch than the 118, keeps shim on top.
Cam Motion Z1 - Similar to K410
There are a dozen cams I could suggest. It depends on where you want the power and how you realistically intend to ride the bike. The cam selected is key to reaching that goal.
If you go with a cam that requires Shim on Bottom valve adjustment, the price goes up hundreds of dollars. Rather than do that, I'd sooner see you go 1197cc and stay with a shim on top cam.
www.flowbenchtech.com/porting/CRH/kz-data.htm
- larrycavan
- Visitor
this is what i want to build,even fits under stock bodywork!
:woohoo:
For Christ sake :laugh: Put a turbo on anything and it rocks. Those things are for guys that can't run N/A motors and besides.....those bikes are as FUGLY as it gets :woohoo:
Oh.... g'day Jimbo ....just twisting your tach needle for you :silly:
- T_Dub
- Thank you received: 25
I'd agree with him fully, all of this is more about how you intend to ride your bike, not how much HP you want it to make. Sure big numbers are fun but you don't want to lose that awesome drivability that these bikes are famous for.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- kzgeary
