bore kit
12 Jan 2011 10:15 #421687 by kzgeary
bore kit was created by kzgeary
wanting to do a 1075 bore kit with 12:1 compression. would it be wise to do that on a stock bottom end, and would the engine hold that much compression.
  • kz1k
  • You Cant Fix Stupid!
12 Jan 2011 10:21 #421688 by kz1k
Replied by kz1k on topic bore kit
welcome to the forum.
1978 KZ1000A2
12 Jan 2011 12:31 #421710 by Nebr_Rex
Replied by Nebr_Rex on topic bore kit
12/1 would require bottom end work.
What are you looking to do with this bike?
12/1 is to high for these engines on todays pump gas, and race and av gas is pricey.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
12 Jan 2011 14:56 #421744 by kzgeary
Replied by kzgeary on topic bore kit
idk i just want to get at lease 110- 125 hp what would be the best way to go
12 Jan 2011 15:16 #421747 by Nebr_Rex
At the crank?
What was the stock horsepower on the bike when new?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
12 Jan 2011 15:26 #421748 by PLUMMEN
Replied by PLUMMEN on topic bore kit
Nebr_Rex wrote:
At the crank?
about 70-75 at reat wheel would be my guess. B)
12 Jan 2011 15:30 #421749 by PLUMMEN
im gonna go out on a limb and say its gonna take more than a set of pistons to reach that number.
id suggest a good cylinder head,cams,carbs to go with it.
12 Jan 2011 15:32 #421750 by kzgeary
i know that but i was just try to get a list of stuff that would make it reach it and it had about 87hp when it was new. i want to do a 1075 kit with 410 cams and rejet my mukuni carbs.
12 Jan 2011 15:41 #421751 by PLUMMEN
what year is it?
the .410 cams are considered border line for needing shim under buckets and other fancy valve train parts.
i personally prefer bigger motors with lower comp and smaller cams that run on pond water,ask anybody whos ever listened to me for more than 10 minutes or tried keeping up with me on a back highway in nebraska/kansas! :laugh:
  • hocbj23
  • Visitor
12 Jan 2011 15:46 #421752 by hocbj23
Replied by hocbj23 on topic bore kit
Im sorry but I dont understand.WHAT is it u are trying to accomplish here?Do u want a drag racer? Do u want a more responsive street bike? Do u want to spend money just so a dyno reads a specific number?U need to spend a little time deciding what u want ur bike to do and then ask for help from folks on here as to how best to reach ur objective.Kits and cams and rejets are bullshoi unless u have a coherent goal in mind.Otherwise ur wasting ur time and ur money.Just mo.bj
  • DoubleDub
  • Visitor
12 Jan 2011 15:57 - 12 Jan 2011 15:58 #421755 by DoubleDub
Replied by DoubleDub on topic bore kit
Those kind of HP numbers aren't very usable unless you're drag racing on these motors. Maybe if you did some form of force induction, but there is still a ton of heat created when you increase performance which will reduce longevity, blah, blah, blah, blah. I think the general consensus is that a drivable motor can do something in the high 80's to 90's and still be reliable for everyday riding?
But again, it all depends on what you are wanting to do.
Don't get me wrong, anything is possible - if you're just wanting to make the engine hit a number and don't care how it drives, the more power to you, just post pics!
Edit: I would think that bigger carbs will be mandatory if you are pushing to get >100HP
Last edit: 12 Jan 2011 15:58 by DoubleDub.
  • andy9802gt
  • If it tastes that good, eat it yourself.
12 Jan 2011 16:02 #421756 by andy9802gt
Replied by andy9802gt on topic bore kit
wow! talk about a buzzkiller.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
