- Thank you received: 225
Do inexpensive rebuild parts even exist?
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- Thank you received: 104
looks like your stuck between omr (hardass) and a fat ass! :S :woohoo:Old Man Rock wrote:
...these old beauties have become collector items due to there's not many more of these old girls around. Then there's old farts as myself who fell in love with these old girls way back when...when they're used up they become extinct in some cases and expensive in others where to some worth very penny...As in my case... sure, I could of went real cheap...just to get the old girl running but I have been waiting for 30 years for this moment...for a 30 year old...crappy screw...that's they way it just works in the world... Any hobby/passion regardless what it is, if the numbers are low, it's not cheap...this analogy is going to cost me...
Fat Trailer Park girl:
6 pack of beer....
Smoking hot babe with a kickin bod:
...trust me.
You go, OMR!
- KaZooCruiser
- Thank you received: 7
Since your post title says it all, you can't afford it, trust me.
You know . . . I was interested in what you had to offer, until I read this smart ass comment.
It isn't the first time I have seen this sarcastic kind of thing on this website.
I came in here a few months ago because I had a problem with a fuel level indicator circuit.
The smart ass in that thread indicated that I should step on the bulb to fix the problem.
If I had a Harley, and asked questions about pistons, someone might have an idea or two about modifying a GM piston to work.
But I come into here. . . and ask a world-wide resource base about parts supplies, and get immature commentary from fools, instead of help.
If you have nothing helpful to offer, don't make jokes at someone else's expense. It doesn't indicate you are very bright when you do.
Jonathan Gilbert
- YUKABODOS
- 9am53
- homebrew, and some bbq
- Thank you received: 3
A lot of the guys here have spent many thousands on their bikes, so when they see a thread asking about cheap rebuild parts it's like walking into a mensa meeting and asking if hooked on phonics works...you have to expect some ribbing.
As has been mentioned call Z1E, or email a specific query to them, they can help for sure. Good luck man, if I can do it so can you, it may just take some more time to get all the parts. I have increased my bike budget for the winter by not going out when my buds go drinking, I have limited my self to ( :S ) 12 beers a week, and I now drink cheap beer. Every little bit helps
Just for the record, a fat trailer park broad with a 6 pack in her will eat like its her last meal.
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- hoghaterkaw
- hardr0ck68
- Who put the what in the where?
Why do you want new pistons and rings? Have you spec. out your old kit? If they are still in speck they will still make the compression you need!
Check your cylinders for round. If they are good and in spec run a hone down them. Then check your rings end gap. If still in spec. run them. If not hunt ebay for used piston sets (ushally go for under $20 for all 4) wait till you can snag a set and check the rings on those.
If you trust file fit parts I have a set of +1mm rings with those you can simply put the rings to the bores and obtain the correct end gap with a file. It takes time to get it right, but eventually you will get the end gap correct. Many folks on this forum do not trust file fit rings, but it is a common practice (google it). I have never tried it, but it does not scare me, i think it would work out well. PM me I will let them go for a fair price.
With these bikes, cheap often means scrounging... it was not always like this. When I first bought my 650 I remember seeing all kinds of cheap parts; but for some reason it all seems to have gotten pricey. If you want I can send some used (but appear to be in good shape) pistons and rings your way....
Guys like OMR blow big money on these bikes and have forgotten, if they ever knew, what it was like to be building on a budget.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- bountyhunter
- Thank you received: 337
Installing oversized rings with the ends cut is a common practice..... but (IMHO) only on an engine you are going to sell. And FYI: oversized rings force fit to a smaller bore will not be round, they will be more egg shaped and not fit the cylinder properly. They may eventually cut the cylinder walls enough to seal. I would also advise using the closest oversize set, as the farther up the worse the fit. I see oversize sets in 0.25mm increments, I would not try to stuff 1mm overs into a standard size bore. Just my opinion.If you trust file fit parts I have a set of +1mm rings with those you can simply put the rings to the bores and obtain the correct end gap with a file. It takes time to get it right, but eventually you will get the end gap correct. Many folks on this forum do not trust file fit rings, but it is a common practice (google it).
- hoghaterkaw
- bountyhunter
Problem is, cylinder wear (even bad wear) is probably only going to be maybe .005". I bored my 750 when it had 75k miles and it was showing about .004" wear on the walls near as I could measure. If you go to a +1.0mm over, that's a full .040" larger diameter than stock and that is really going to be out of round forced into the bore. I initially considered using a +0.25 over (which is .010" over) in the stock honed cylinders because the wear on the walls would put the cylinder diameter halfway between stock and +0.25mm over. In the end, I just had it bored +0.25mm over and bought pistons and rings. Definitely the smart move.
- will61310
- Thank you received: 6
...1980 LTD 1000...
- Old Man Rock
Give me a break... Wasn't born with a silver spoon... Earned my college funding through serving in the ARMY, no mommy/daddy's money there for there wasn't any money to be spent... What was there's is still there's, not mine.
As for BIG bucks spent, you have no idea what I spent on my KZ especially since I accomplished 98% of it myself...
As for taking insult to the heading... Seriously as mentioned from myself as well as others.... This is a 30 year old motorcycle and parts are limited, thus Supply & Demand is the game...
Now before getting your feelings all hurt, this is for anyone interested in rebuilding old vehicles, cars or old KZ's for that matter... If you can't afford a $10 gasket, or the cost of some of these specialized parts then wait as I did, 30 freaking years before doing so when you can afford it...
We've all been there, concrete blocks or milk crates for stereo stands, rice & hot dogs or top ramon with some spam, sounds like crap now but hey, that was some really fine dinning way back when... Let's see, I have $20 for the week, gas or beer... Hey, how about a little of both... Yeah, I've been there dickweed.
So if you feel myself or others are making fun of your financial status then you have us figured out all wrong.
We provided you a good source of reasonable KZ parts @ Z1 for example, e-bay you name it...
You started this post with a question and the answers had been provided... Sorry you didn't like the answers you received but this is the fact of the matter...
Collectors items aren't always cheap.
Well, I feel better...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
