Do inexpensive rebuild parts even exist?
- KaZooCruiser
11 Oct 2009 17:49
It's getting time to re-ring my '78 650, and the head gasket at the dealer is 94 dollars, and the rings are over 250.00.
I saw a wiseco kit on ebay and that was 498 for 4 pistons and rings.
I thought motorcycling was supposed to be economical. . .
- TerryK
Re: Do inexpensive rebuild parts even exist?
11 Oct 2009 17:55 - 11 Oct 2009 17:56
Go to Z1 Enterprises and get aftermarket parts. OEM gaskets are waaay overpriced.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 11 Oct 2009 17:56 by TerryK.
- bountyhunter
11 Oct 2009 18:10
Rings for the four-hole engines are pricey. Rebuild gasket sets are available, quality is iffy.
- will61310
11 Oct 2009 18:18
Ive heard of some counterfeit gaskets going around on Ebay, so i'd stick with a reputable place like Z-1, they should have everything you will need...
...1980 LTD 1000...
11 Oct 2009 18:30 - 11 Oct 2009 18:31
I don't know what model KZ650 you have, or if you need oversize rings, but I would check eBay for NOS Genuine Kawasaki parts. (First check Kawasaki.com to know what part numbers you need) You'd be surprised at the deal you can sometimes find. I bought a set of NOS standard size genuine Kaw rings (for all 4 cylinders) for just $25 in case I need them in the future. Here are some head gaskets, some are genuine Kaw, for a couple different KZ650 models:
KZ650 Head Gaskets
KZ650 Head Gaskets
Last edit: 11 Oct 2009 18:31 by 650ed.
- TeK9iNe
- What did you do!?!
11 Oct 2009 18:48
Z1 Enterprises for practically everything.
I've gotten so much @$#^%! from flea-bay that was just cleaned up, I can't go there anymore.
Flea-bay is ok, for the most part. But for my time and money, and MY ENGINES - MY BABIES. Everything new. Period.
For all the gaskets except the head, just use liquid gasket maker.
www.z1enterprises.com/
Peace.
Peace.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- BSKZ650
12 Oct 2009 05:43
650 std rings are damn near noexistant, I would suggest that you take it apart first and measure everything, chance are you will need to bore it out and go to oversized pistons, which are aval in kits.
I have learned the hard way CHEAP is not always the best way to go, fix it once and right the first time
77 ltd1000, current rider
76 kz900, just waiting
- Mcdroid
- Gone Kwackers
12 Oct 2009 07:35
BSKZ650 wrote:
...what he said...
...what he said...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- KaZooCruiser
12 Oct 2009 14:00
I went to Z1. . .and got confused / frustrated and I gave up after about 15 minutes.
"Parts by make"
"Kawasaki"
"small fours"
"Kz650"
"Kz650-D1A 1978"
so far so good, right?
"engine"
Cam chain guides, dampers, pistons, rings, clutch, shims, etc
no pistons listed
Do a search for "piston"
no pistons for 650
Do a search for "piston ring"
no rings for 650
The site needs work. . .sorry
"Parts by make"
"Kawasaki"
"small fours"
"Kz650"
"Kz650-D1A 1978"
"engine"
no pistons listed
no pistons for 650
no rings for 650
- Locozuna
12 Oct 2009 15:03
KaZooCruiser wrote:
:woohoo: :laugh: :woohoo: :laugh: :woohoo: :laugh:
Economical? As opposed to a moon mission it is. Economical is working on it yourself as opposed to getting a shop to do it. A Z1 is economical as opposed to going the same distance in a Z28.
As was said you will prob need to get a kit as the stk. rings are becoming unobtanium. And as for Z1Enterprises call them.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- timebomb33
12 Oct 2009 15:14
i have over 8,000 into my 1393 big block and all i have done with it is make 15 or so dyno run's and three drag strip passes and buddy it was worth every penny because it was intense and once i get the cylinder studs to keep from pulling out of the cases, i'd spend another 8 grand on it again because it is that much of a rush building and riding something that you built with your own two hand's and going quicker than you have ever gone before what a rush.
I THINK MY POWERBAND BROKE
- roy-b-boy-b
12 Oct 2009 15:49
Call them at Z1enterprises. They are friendly and very helpful. Just push option 2. ask for Jeff or Rob.
I don't order over the computer. I just call. Roy
