1973 Z1 Maui
  • Mikaw
14 Dec 2021 08:12 - 14 Dec 2021 08:13 #859063 by Mikaw
Replied by Mikaw on topic 1973 Z1 Maui
Correct on the brn/wht, and the dual female brown. Extra not needed. Good for accessories.
www.wgcarbs.com/index.php/using-joomla/e...-categories/89-coils
Here’s the Wired George relay schematic
Last edit: 14 Dec 2021 08:13 by Mikaw.
  • MauiZ1
  • Topic Author
14 Dec 2021 12:58 #859076 by MauiZ1
Replied by MauiZ1 on topic 1973 Z1 Maui
Cool! I may do that.
Melekalikimaka
  • hardrockminer
  • Away
14 Dec 2021 17:28 #859087 by hardrockminer
Replied by hardrockminer on topic 1973 Z1 Maui
Melekalikimaka
That could be a great song!
  • slmjim+Z1BEBE
15 Dec 2021 06:15 #859094 by slmjim+Z1BEBE
Replied by slmjim+Z1BEBE on topic 1973 Z1 Maui
What is the relay for the coils for? Does it keep the current from going through the handlebar controls?
Z1/KZ ignition switches, and motorcycle ignition circuits in general can introduce voltage drop at the coil primaries, reducing spark energy.
  The relay bypasses the ignition and kill switches, in order to supply full battery power direct to the coils through the NO relay contacts, while still retaining operation of the kill switch.  The harness we developed is plug & play, with no butchering/cutting/crimping of any OEM wiring necessary; we just crimp matching bullet and ring connectors the the relay harness and battery power connections, respectively.  The relay harness can be simply unplugged from the main harness and coil wiring, enabling the bike to be returned to it's factory original wiring configuration in under ten minutes after the tank is removed.
We were compelled during the resto of our '72 Z1, 'The Seven Year _itch', to disassemble an OEM ignition switch to correct an intermittent issue.  The internal construction we found suggests that the design of the rotary contacts was barely adequate, at best, for the current load imposed, particularly on the circuit feeding 12V to the coils.  See our post linked below:
kzrider.com/forum/4-electrical/606810-z-...-and-troubleshooting
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
15 Dec 2021 06:52 #859097 by Move0ver
Replied by Move0ver on topic 1973 Z1 Maui
If this is a restoration that's going to be ridden vs displayed, I'd go with a modern wiring harness.
PMC makes this one:
japan.webike.net/products/1523082.html
it's pricey, but I'll never go back to an OEM harness on an old bike.  I have it on mine and it's been nothing but amazing.
  • MauiZ1
  • Topic Author
15 Dec 2021 07:10 #859098 by MauiZ1
That really looks nice. I may need to try that.
15 Dec 2021 07:53 #859102 by Move0ver
here's a write-up I did including lessons learned:
kzrider.com/forum/4-electrical/608400-pm...s-install-and-review
It has an accessory power connection at the headlight too, which is nice.
  • MauiZ1
  • Topic Author
15 Dec 2021 13:53 #859121 by MauiZ1
The Sohc Hondas suffer from similar electrical issues. I think I will solder up a relay for the start circuit on this Z1, seems like a safe thing to do for increased reliability. Thank you all for the great information.
  • hardrockminer
  • Away
15 Dec 2021 16:20 #859134 by hardrockminer
I did the Wired George relay addition to my 1980 KZ1000 and it runs perfectly.  I bought a second kit to put on my Z1B but I've never installed it.  Maybe this summer.
  • MauiZ1
  • Topic Author
16 Dec 2021 13:32 #859174 by MauiZ1
I’m looking over details on the carb hoses.
the bowl overflows gather together and drop down over the back of the motor toward the swing arm.
where do the two 6.5mm bowl vents go besides just up? They are listed as 140mm long in Brookes.
thank you
  • MauiZ1
  • Topic Author
16 Dec 2021 13:38 #859175 by MauiZ1
On another note
i am trying to get a machinist friend of mine to make me a set of the nylon choke plunger collars. If he is interested I may try to get him to make more of whichever style someone needs, would any of you be interested?
  • hardrockminer
  • Away
16 Dec 2021 16:37 - 16 Dec 2021 16:38 #859180 by hardrockminer
No eBay APP ID and/or Cert ID defined in Kunena configurationYes, just up...towards the front of the air intake.  On later models there is a hole in the brace just in front of the airbox where I put the ends of mine.
Can you flash a photo of the nylon choke thingys?  I think yours are different from later versions.  But if not, there are several people selling new ones on ebay.
Search this part number on ebay.  293416898481
Last edit: 16 Dec 2021 16:38 by hardrockminer.
