Peavylotus' Rebuild of the KZ Cafe
- peavylotus
- Movin on up
Re: Peavylotus' Rebuild of the KZ Cafe
11 Jan 2014 02:16
A mini project I had with the coils.
This is the state I received the coils in. A bit dirty is all. So I cleaned them up with acetone.
partial view of them, more will come down the list.
Next, I addressed the dirty and gunky terminals
I put some new gold plated nuts on them with gold plated washers with some connectors in which I will solder to the main harness which I am constructing now.
This will give it a solid connection that I wont have to worry about.
After this I took notice of the mounts. The bolt and washers looked terrible. With a little washer modification I was able to clean it up a bit. This is what it looked like before modifying them.
This is the washer mod
And the washer mod result
Attachment 3.jpg not found
Attachment 5.jpg not found
Attachment 6.jpg not found
Attachment 7.jpg not found
Attachment 8.jpg not found
Attachment 9.jpg not found
1980 KZ 1045 LTD Currently Workin' It Out
- peavylotus
- Movin on up
11 Jan 2014 02:25
More of the results. Just looks more purpose built rather than slapped together.
Next was the other side of the coil, This was a bit trickier with the plastic sleeve. So washer mods were extended!
This is the mod. Two more cuts
With two washers it becomes level with the plastic sleeve.
End result looks like this.
And this
Attachment 10.jpg not found
Attachment 11.jpg not found
Attachment 12.jpg not found
Attachment 13.jpg not found
Attachment 14.jpg not found
Attachment 16.jpg not found
Attachment 15.jpg not found
And this
Attachment 16_2014-01-11.jpg not found
- peavylotus
- Movin on up
11 Jan 2014 02:33
This is how the whole setup turned out
The Dyna 2 Stage is pretty F'n sweet, I can't wait to get it all hooked up. This picture shows the perameters it controls.
Very happy with my ignition setup and am piecing the bike back together. More pictures to come, as I made much more progress this afternoon.
Attachment 18.jpg not found
Attachment 19.jpg not found
Attachment 20.jpg not found
Attachment 21.jpg not found
Attachment 22.jpg not found
- peavylotus
- Movin on up
28 Feb 2014 22:24
Got the engine back together. Next is to wire in the 2 Stage limiter, electro tach, the sweet accel coils, lights, horn and blinkers. That will be pretty fun. I made a bare bones harness before but now I am making pretty much a factory extensive harness so Itll be a tough one.
(Picture won't insert because I'm on mobile)
- peavylotus
- Movin on up
28 Feb 2014 23:10 - 28 Feb 2014 23:33
Not the best picture but it s where I'm at
Attachment kz1000.jpg not found
Last edit: 28 Feb 2014 23:33 by peavylotus. Reason: Picture issues
- lightitup
01 Mar 2014 00:34
looks great how much more do u have to do
81 kz 550 ltd
- peavylotus
- Movin on up
01 Mar 2014 00:49lightitup wrote: looks great how much more do u have to do
Wireing harness, seat bracketry, exhaust and brakes as well as any quirks that come after she starts up. I do have to do valve shims because of tight tolerances but I plan to buy a new head during the summer so I'm putting it off.
I kicked it over with the sparkplugs in and the difference was night and day with the newly bored cylinders I'm so stoked for this
- crusierlover
01 Mar 2014 03:45
It looks so good so far.You are very talented.
Proud owner of 1982 650csr again soon. keeping it this time
The following user(s) said Thank You: peavylotus
- peavylotus
- Movin on up
01 Apr 2014 14:24
Well, I have been moving slow but I am back on track with a new tool even. I have been talking about doing a video series on Youtube and well thats what I am doing now. I've decided to go ahead with the brake conversion and here is a video about the bracket and my CNC machine.
- kaw-a-holic
01 Apr 2014 16:48
Cool.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- peavylotus
- Movin on up
03 Apr 2014 22:17
Made a little holder for the electrics so they weren't bolted to where ever was available. I am so happy with the results. I pocket milled the reg/rec, cut an opening just big enough for the top section of the battery to fit flush (the body of the battery is 1mm wider that the head of the battery) and I mad a hole for the rev limiter to be inserted from behind.
The little slot next to the rev limiter wire was for the wires to run out of the bottom but I cut it on the wrong side, though I like the wires from the top because they would interfere with the mounting brackets on rev limiter. I think it calls for the famous word of bob ross 'We don't make mistakes, it's just a little happy accident'. haha
Attachment IMG_20140403_190639_196.jpg not found
Attachment IMG_20140403_210424_168.jpg not found
Attachment IMG_20140403_210433_077.jpg not found
Attachment IMG_20140403_210441_126.jpg not found
Attachment IMG_20140403_210400_771.jpg not found
04 Apr 2014 06:26
looks sweet!
love the bob ross reference,got a chuckel outta that.
will the plastic take the heat generated by the ignitor?
