HollywoodMX's Drouin Supercharged 77 KZ1000!!
- Hollywoodmx
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
23 Mar 2013 00:57531blackbanshee wrote: what is up with the engine in the bottom pic?
looks like 650 bottom with a 900/100 top end :blink: .
Frame is modified, look no bottom engine support. Also look at those rubber mounts on the the sides..(drool). That or it isn't a kz frame.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Hollywoodmx
24 Mar 2013 21:00
Ok now I need some help. 3 items.
1. First is feedback on chopping the seat. I want it to be a single seater. I used black tape to show where I will cut. How does it look? should I modify such an old kit?
2. Rear set placement. Still not sold on my card board template placing them in a good place. I think they need to go back further.. Thoughts?
3. My shock mounts on the frame are not wide enough because the clutch side shock will hit the chain using the stock mounts. Is it ok to extend them with some kind of custom insert or something?
Seat chop:
Rear sets:
Seat chop:
Attachment 20130324_165147.jpg not found
Attachment 20130324_165153.jpg not found
Attachment 20130324_165159.jpg not found
Attachment 20130324_165248.jpg not found
Attachment 20130324_165255.jpg not found
Rear sets:
Attachment 20130324_144644.jpg not found
Attachment 20130324_144649.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- les holt
24 Mar 2013 21:03Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- Hollywoodmx
24 Mar 2013 21:04
My shock issue:
Attachment 20130324_165314.jpg not found
Attachment 20130324_165338.jpg not found
Attachment 20130324_165402.jpg not found
Attachment 20130324_165410.jpg not found
Attachment 20130324_165446.jpg not found
Attachment 20130324_165452.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- zed1015
24 Mar 2013 21:18Hollywoodmx wrote:531blackbanshee wrote: what is up with the engine in the bottom pic?
Frame is modified, look no bottom engine support. Also look at those rubber mounts on the the sides..(drool). That or it isn't a kz frame.[/quote
It's a 750 ZEPHYR engine AND frame.
25 Mar 2013 11:16 - 25 Mar 2013 11:18
i had to space my upper shock mounts out to clear my 200mm rear tire,no biggie.
i just machined out some aluminum spacers and washers.
the shortened tail looks good the way you have it "taped"out,i might want a little radius at the front instead of cutting it square tho.
the complete underside of the seat/tail might need a radius that went up a lil towards the tail instead of just being straight.
kinda like the underside of a kz tail.
i wouldn't hesitate to make the mods to the body kit if it was mine.
the pegs look like they are plenty far enough back and up.
but,
you can sit on it and test it.
so,
make it fit you.
hth,
but,
so,
make it fit you.
hth,
Last edit: 25 Mar 2013 11:18 by 531blackbanshee.
- Hollywoodmx
25 Mar 2013 14:26531blackbanshee wrote: i had to space my upper shock mounts out to clear my 200mm rear tire,no biggie.
but,
so,
make it fit you.
hth,
Awesome thanks for the feedback and assistance.
I get what you mean about the rounding of the fender. Its a good idea.
I know what you mean about the spacers. So for your shocks did you maintain the original bolt length and had enough threads for the bolt to grab?
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
25 Mar 2013 16:06Hollywoodmx wrote:531blackbanshee wrote: i had to space my upper shock mounts out to clear my 200mm rear tire,no biggie.
but,
so,
make it fit you.
hth,
after moving it out i could get about 5-6 threads.so far that has been enough.
- Hollywoodmx
Ok, how strait is the shock mounted from the frame to swing arm cause on my last pic, its not strait and that's with one or two threads..I think I will need an extension..
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 25 Mar 2013 23:44 by Hollywoodmx.
- Haybus
- Big Al
26 Mar 2013 01:23
Make a spacer that slides over the shaft part of the shock mount to space out the shocks. Then make a nut the same OD as the shock mount with an internal thread and a hex head. The nut would be ~1mm short of bottoming so it can clamp the shock eye. Yeah, it's going to be a thin wall nut. Seems like you're too far along to cut off the mount to weld on a new one.
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
26 Mar 2013 10:58they are straight and square
you could drill and tap the center of the stud,and spin out a sleeve/spacer that covered the threads and made them the same size as the rest of the stud then a little custom washer and allen head and bam yer done!
26 Mar 2013 11:19
if i could draw your attention to the upper shock mount on this bike to illustrate what i am talking about with a bolt and countersunk washer.
