HollywoodMX's Drouin Supercharged 77 KZ1000!!
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
06 Apr 2013 17:14
#580903
Well I know chopping the seat was a nessesary evil, but I regret doing it due to the added work.. :dry:
This is what I am doing to fix the gap to the tank now. Once all set I will shape it properly so ignore the extra material.
Attachment 20130406_123851.jpg not found
Attachment 20130406_123858.jpg not found
Attachment 20130406_123928.jpg not found
Attachment 20130406_125932.jpg not found
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • Hollywoodmx
06 Apr 2013 21:28 - 07 Apr 2013 12:29
#580939
Fully cleaned up the triples and painted them. My forks have scuffs here and ther but I dont know what to really do with them. I heard they are not paint friendly..
WHOLLY GREEN ROTORS BATMAN!! :silly:
Attachment 20130406_164450.jpg not found
Attachment 20130406_164503.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 07 Apr 2013 12:29 by Hollywoodmx.
  • Hollywoodmx
15 Apr 2013 18:22
#582524
So it's been a bit quieter in the ole grease monkey garage. Been on-line shopping more than building.
The bad; made little progress, the good; a bunch of cool shit on the way! :)
Nice 1" aluminium spacer for my new intake manifold for my S&S E carb. I wanted a slightly longer intake tube to allow the fuel to atomise better. The stock setup with the carb bolted direct to the super charger seemed a bit "non engineered" to me.
Man what a slow down it has been after fucking with the seat. It's actually slowed me down quite a bit cause I cant prime anything until the seat is ready for paint. I had to cut the new fiber glass work and redo the seat. It looked good at the early stages of setting but it slipped in one corner resulting into cutting it all and redoing it. This time I set it touching the gas tank to set. It's all a learning experience. I also further examined the other bimota seat and there more room for me to thin the seat hight dimension wise, so I have a plan for that.
I prepped the tires for paint! And the rotors clear coat went well. I just got to clear coat the trips and I'm good to go to put the front back together.
My buddy is making me the shock mounts for the swing arm and I will have to use leon's trick for the shock bolts on the frame. Are the shock bolts welded in?
Attachment 20130414_152433.jpg not found
Attachment 20130414_152615.jpg not found
Attachment 20130414_183233.jpg not found
Attachment 20130414_183258.jpg not found
Attachment 20130414_183348.jpg not found
Attachment 20130414_183404.jpg not found
Attachment 20130414_183419.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
16 Apr 2013 16:24
#582697
i figured that the super charger would be atomizing the fuel about all it could be :huh: .
you know like grandma mixing up a cake :P !!!!!!!!!!!
keep us posted.
  • kzz1king
  • kzz1king's Avatar
16 Apr 2013 17:10
#582699
I would think any drop out would occur after the mixer, not before. Wouldn't increasing the distance between the blower and the carg increase dropout at that point?
Wayne
Home built KZ1000 turbo setup
  • zed1015
  • zed1015's Avatar
  • Away
16 Apr 2013 19:19 - 16 Apr 2013 20:23
#582715
This is my manifold i modified to take a super 'G' with the mouth opened out so that the fuel gets pulled across the maximum lobe area.
Works just fine and fuel dropout definatly won't be a problem you'll have. Believe me ! ;)
[IMG
[IMG
[IMG
[IMG
Last edit: 16 Apr 2013 20:23 by zed1015.
  • 531blackbanshee
  • Vendor
  • Vendor
16 Apr 2013 20:59
#582728
No half steps there zed :woohoo: !!!!
You are a bada$$ :evil: ......
Leon
  • Tomolu5
  • Tomolu5's Avatar
16 Apr 2013 23:59
#582750
Umm...I'm kind of lost on the green rotors, is this a show only bike, or is there some paint technology I'm not aware of? Forgive me for not having time to read the whole thread, but I will.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • Hollywoodmx
17 Apr 2013 10:53
#582791
531blackbanshee wrote: i figured that the super charger would be atomizing the fuel about all it could be :huh: .
keep us posted.
The super E is a big carb. It's known for poor atomisation on the MJ. The thunder jets will make it much less an issue though. I wanted the extension for the same reasons as zed explained as well. Like I said earlier I don't think the manifold was engineered well stock and the stock flange was pretty much "on the lobes" and the old hole diameter covered only about 20% of the lobe area. It's my opinion this design results in less power. I wanted the intake manifold to be wider and longer (Plus I need some clearance fit-meant wise). My manifold will be similar to zeds but I'm actually going to attempt to make mine slightly wider. I bought the adaptor for a few other reasons as well. To be a new flange to weld to and I wanted more vacuum pressure built up before hitting the wide part of the manifold. If it ends up being too much intake manifold volume I will put a divider plate in the adaptor portion.
Tomolu5 wrote: Umm...I'm kind of lost on the green rotors, is this a show only bike, or is there some paint technology I'm not aware of? Forgive me for not having time to read the whole thread, but I will.
Not a show bike at all. The rotors are green cause I wanted green rotors! lol.
I'm just bugging, I know what your asking, the overspray.. Basically the paint that's on the rotors where the brake pads will touch will last only a few minutes of braking leaving a nice line that I never had to tape. I promise you the paint on the brake portion of the rotors is only over spray so it's quite a bit lighter.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • Hollywoodmx
19 Apr 2013 21:17
#583174
Shock mounts produced! BEEEEEEFFFFFYYY.
My buddy Jason made these ones. The one in the pics is the right side due to the swing arm is thinner on the right..
Attachment IMG_5472.jpg not found
Attachment IMG_7863.jpg not found
Attachment IMG_9705.jpg not found
Attachment IMG_49602.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • porchev914
  • porchev914's Avatar
20 Apr 2013 16:22
#583319
Lookin good! :woohoo: It's nice to have friends that can help you out, isn't it? B)
FRANKEN Z!
  • Hollywoodmx
20 Apr 2013 22:41
#583374
porchev914 wrote: Lookin good! :woohoo: It's nice to have friends that can help you out, isn't it? B)
Ya it is for sure. I wish I had more than a 1-2 days week to spend on the bike.
Updates; Wheels have the first coats of automotive urethane. (Ran out! Doh!
And the SEAT (the bane of my build now) I had the re-enforce the gaps from the last mod. Hopefully its dry tomorrow so I can finally finish it.
Attachment 20130420_184946.jpg not found
Attachment 20130420_185017.jpg not found
Attachment 20130420_185033.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
