HollywoodMX's Drouin Supercharged 77 KZ1000!!
- Hollywoodmx
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
17 May 2013 23:38 - 17 May 2013 23:43
When I got back from vacation this week I tackled a few more things.
Got the shock mounts welded on the swingarm.
Got the base coat done on the body parts and finished the first color layer of the base on the wheels. It's urethane across the board on all items. It's my first time using the gun and overall I'm quite happy with the results. Also VERY happy with the 2k primer. The 2k primer was super smooth, I'm quite stocked for the 2k clear now.
Decided to paint the rear sprocket too (etching primer in the pick)..lol. Might as well, need some green contrast in the rear too.
Some more work happening this weekend as well.
Attachment 20130515_212502.jpg not found
Attachment 20130515_212509.jpg not found
Attachment 20130515_212451.jpg not found
Attachment 20130515_212430.jpg not found
Attachment not found
Attachment 20130515_212441.jpg not found
Attachment 20130515_212638.jpg not found
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 17 May 2013 23:43 by Hollywoodmx.
- CruisingRam
18 May 2013 08:15 - 18 May 2013 08:18
I believe that right side bracket will absolutely fail at some point without a gusset, I suggest the top side to keep from interfereing with the chain adjusters. The shock is mounted in shear with the swing arm, and you are correct, the bending moment is right on the plane of the shock mount. And Aluminum fails without notice! Two small gussets from the flat side of the swing arm to the shock mount would prevent that from happening IMHO.
This is the pic I see the problem in
But man, don't think I am critisizing what you have done here- this bike is fantastic! Just another pair of eyes seeing a potentional load problem!
Haybus wrote: Yeah, I saw that. I'm speaking specifically about your right mount you had machined. You have a sharp corner where the clevis meets the extension you plan to weld to the swingarm. You have a bending moment because the load path is offset from the swingarm. While the size and thickness may take a great deal of load, it's getting hammered constantly during riding which can lead to fatigue failure. Sharp corners are bad for fatigue. A gusset underneath would help.
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
Last edit: 18 May 2013 08:18 by CruisingRam.
- zed1015
18 May 2013 08:59CruisingRam wrote: I believe that right side bracket will absolutely fail at some point without a gusset, I suggest the top side to keep from interfereing with the chain adjusters. The shock is mounted in shear with the swing arm, and you are correct, the bending moment is right on the plane of the shock mount. And Aluminum fails without notice! Two small gussets from the flat side of the swing arm to the shock mount would prevent that from happening IMHO.
Don't think that is an issue now as the mount appears to be directly on the arm as per the left mount in the new pic's.
- Hollywoodmx
18 May 2013 14:56zed1015 wrote:CruisingRam wrote: I believe that right side bracket will absolutely fail at some point without a gusset, I suggest the top side to keep from interfereing with the chain adjusters. The shock is mounted in shear with the swing arm, and you are correct, the bending moment is right on the plane of the shock mount. And Aluminum fails without notice! Two small gussets from the flat side of the swing arm to the shock mount would prevent that from happening IMHO.
Good eye Zed. The original mounts were over engineered on purpose so I had material to shave off vs missing material, that was the design I asked for. When I started in fully dialling in the angles (after the previous pics I posted) and got the spacing down to the exact mm on both sides, the right mount end up moving closer in to the swingarm. This was also because I was able to get a few more threads in on the left side bolt. I also levelled the swing arm (shock mounts height wise) as the right side was slightly taller.
I know that last pic wasn't the best so I will take some more once I fully clean up the welds. The painting is the priority this weekend. If I have time I will clean up the swingarm and take more pics.
Overall I'm starting to get quite excited as two more major milestones are nearly completed, the paint and the swingarm/shocks. This is will get me my rolling chassis as I didn't want to remount the wheels until the clear is done on them.
The last remaining "major" obstacle is the new carb manifold. Then a whole bunch of smaller ones..
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Hollywoodmx
19 May 2013 00:02
3rd coat of base and second stage of base on the wheels and a hulk sprocket!
Attachment 20130518_194449.jpg not found
Attachment 20130518_194507.jpg not found
Attachment 20130518_194512.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Hollywoodmx
20 May 2013 21:18
Base done just need some touch up on the wheels. Swingarm mounts all cleaned up.
Attachment uploadfromtaptalk1369095381367.jpg not found
Attachment uploadfromtaptalk1369095396673.jpg not found
Attachment uploadfromtaptalk1369095409344.jpg not found
Attachment uploadfromtaptalk1369095421651.jpg not found
Attachment uploadfromtaptalk1369095447565.jpg not found
Attachment uploadfromtaptalk1369095463543.jpg not found
Attachment uploadfromtaptalk1369095471869.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Haybus
- Big Al
20 May 2013 21:45
That load path looks good now. Is your wheel going to be half white and half black?
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
- Hollywoodmx
21 May 2013 02:51Haybus wrote: That load path looks good now. Is your wheel going to be half white and half black?
Yes sir. The whole bike will be black and white with the tid bits of green. Also have some custom graphics for the bike once all the parts are clear coated.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
21 May 2013 09:53
i kinda like the flip flop black and white wheel combo
still waitin to see you bring the candy cane striped header in and win me over tho :laugh: !
keep us posted,
keep us posted,
- kzz1king
21 May 2013 11:36
Gonna be fun to see how it all works together. I am just to conservative or chicken to do something like this! Hats off to you.
Wayne
Wayne
Home built KZ1000 turbo setup
- Hollywoodmx
21 May 2013 22:12531blackbanshee wrote: i kinda like the flip flop black and white wheel combo.
keep us posted,
Ya I like how the wheels turned out too. To be honest the candy cane exhaust to me sounded cooler in theory then execution but I decided to keep it but I'm not sure If I am sold on it as well so I am waiting until the end to see. Worst case I have have it solid black in a weekend.
kzz1king wrote: Gonna be fun to see how it all works together. I am just to conservative or chicken to do something like this! Hats off to you.
Wayne
Thanks man. Ya I'm getting excited as it's getting closer and I want to get to the point where I can tie it all together for everyone. I want it to be crazy yet cool and not gotti like the over done busa's and gixers, etc.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
22 May 2013 09:54 - 22 May 2013 09:55
i hear ya on the header,i have had several ideas that looked better in my head than in real life :sick: .
and if it doesn't tie in like you want,like you say paint it black.
i'm just giving you a hard time.
it seems like you take it well :lol: .
i can't wait to see how it turns out. :evil:
Last edit: 22 May 2013 09:55 by 531blackbanshee.
