HollywoodMX's Drouin Supercharged 77 KZ1000!!
  • porchev914
  • porchev914's Avatar
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
26 Feb 2013 19:15
#574288
Is the Bimota tank fiberglass?
FRANKEN Z!
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
28 Feb 2013 01:22 - 28 Feb 2013 01:24
#574508
porchev914 wrote: Is the Bimota tank fiberglass?
Not entirely. I'm not sure what it is exactly, it could be a mixture. It's fairly heavy and its definitely not fibreglass on the bottom, on the bottom its like a thick urethane or something but the form on the viable areas seems to perfect/flat for urethane or polymer.
Some mid week updates;
Further flattening out the top fins.
Attachment IMG-20130226-00019.jpg not found
Attachment IMG-20130226-00020.jpg not found
Attachment IMG-20130226-00022.jpg not found
Attachment IMG-20130226-00023.jpg not found
Attachment IMG-20130226-00024.jpg not found
Stripped and sanded the top triple clamp.
Attachment IMG-20130226-00021.jpg not found
New extra large headlight arms came in! They are BEEFY. :)
Attachment IMG-20130227-00029.jpg not found
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 28 Feb 2013 01:24 by Hollywoodmx.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 Feb 2013 11:29
#574540
gettin a lil closer :evil: .
keep us posted,
  • Hollywoodmx
02 Mar 2013 00:12 - 02 Mar 2013 00:17
#574828
Mini update with a bigger update tomorrow.
Mr swingarm meet, "laser, blazer and taser" (Dodge ball). :silly:
Going to need lasers to center then align the beast..
Attachment 20130301_153023.jpg not found
My new seat pan is done. 2 tone sun resistant snow mobile vinyl.
Attachment 20130301_183833.jpg not found
Also bought my tires;
Metzeler Sportec M5 Interact
120/70/17
190/55/17
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 02 Mar 2013 00:17 by Hollywoodmx.
  • Hollywoodmx
03 Mar 2013 02:03 - 03 Mar 2013 02:06
#575020
Ok.... Swingarm all fabbed up!!! One of the milestones done! :cheer: :cheer: :cheer:
Using the lazer I had it on the center cast line in the wheel to the pivot area. Just to be sure I made a Canadian white trash plumb to double check and it lined up exactly!!
It was offset by 5mm on one side. I used all hand tools in my garage to do it. I took it slow to be bigger then slightly reduce and keep trying. I had to grind off the right peg holder that's welded to the inner pivot area of the frame otherwise it doesn't make any other contact to anything else.
Attachment IMG-20130302-00030.jpg not found
Attachment IMG-20130302-00032.jpg not found
Attachment IMG-20130302-00033.jpg not found
Attachment IMG-20130302-00034.jpg not found
Attachment IMG-20130302-00035.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 03 Mar 2013 02:06 by Hollywoodmx.
  • donthaveakawman
  • donthaveakawman's Avatar
03 Mar 2013 17:44
#575094
if there is a supercharger heaven white zombie didn't put this in the music video.
  • Hollywoodmx
04 Mar 2013 04:28 - 04 Mar 2013 04:33
#575237
donthaveakawman wrote: if there is a supercharger heaven white zombie didn't put this in the music video.
That's because there isn't room for a alcohol injected supercharged kz1000 with a 57mm carb in heaven... :evil:
In the end I'm building the bike for me, no one else.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 04 Mar 2013 04:33 by Hollywoodmx.
  • Hollywoodmx
05 Mar 2013 00:40
#575358
2 major milestones in one weekend!
Steering stem now modified to fit in R1 trips. My buddy welded the bung in thus the discolouration. The machining was perfect to the millimetre.Bushing was made out of steel so it could be welded to the kz stem.
Attachment 20130303_183229.jpg not found
Attachment 20130303_184023.jpg not found
Attachment 20130303_190855.jpg not found
Attachment 20130303_193124.jpg not found
Attachment 20130303_212014.jpg not found
Attachment 20130304_202123.jpg not found
Attachment 20130304_202033.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • 531blackbanshee
  • Vendor
  • Vendor
05 Mar 2013 10:43
#575424
thats how you do it :evil: !
good job fellas :)
did he weld the bushing on the bottom of the stem?
  • Hollywoodmx
05 Mar 2013 12:33
#575439
531blackbanshee wrote: thats how you do it :evil: !
good job fellas :)
Ya he did. Big fat weld all the way around. Its not going any where. Probably would have to machine it out to get it out of the lower trip cause I flared out the bottom as well for super safety.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • DesertKZ
  • DesertKZ's Avatar
06 Mar 2013 19:22
#575700
Awesome build, literally can't wait to see the finished product.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • Hollywoodmx
10 Mar 2013 01:17
#576302
Well I thought I cleaned the wheels but they needed a rigorous cleaning took forever. New tires came in so I mounted them. Tomorrow will be a big day as I will test fit the forks and swingarm with wheels and tires.
Also sanded the burnt clear coat on the lower trip.
Attachment 20130309_165904.jpg not found
Attachment 20130309_165841.jpg not found
Attachment 20130309_181530.jpg not found
Attachment 20130309_181602.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
