'76 KZ900 (ZRX1200R) Build
  • NakedFun
  • NakedFun's Avatar Topic Author
Re: '76 KZ900 (ZRX1200R) Build
05 Dec 2012 00:25
#561425
Mark is always the voice of reason around here! I think I may still do it anyway. May not be too bad. When I call D&G next week to place an order for parts, may need to see if they'll unleash their CNC to make the spacer...
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Dec 2012 20:27 - 05 Dec 2012 20:29
#561524
NakedFun wrote: Mark is always the voice of reason around here!
Cory
funny, my wife never says that,when i try to reason with her to buy more buying parts. :laugh:
I'd love to see u do this. Have fun with it. B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Dec 2012 20:29 by mark1122.
  • NakedFun
05 Dec 2012 23:08
#561560
So I think I may have an idea to get around the hard part of the spacer. I am going to start by using the extra stator cover and milling it down until it just has enough depth to keep the starter components in place. Then have a CNC disc made with a step in the edge and a center hole. That will drop the disc into the cover opening and have it welded in place. Then I can drill and tap the plate to make an indexing plate for mounting the alternator.
The second option is to use tubular stand offs and use 1/8" or 1/4" bar stock and cut them in sections to weld in between the posts to create a fabricated spacer.
Lastly is an 18 lb, $90 slab of aluminum and lots of time cutting and filing.......
Cory
1976 Kawasaki KZ900
  • badrhino
  • badrhino's Avatar
05 Dec 2012 23:36
#561570
Looking good.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • NakedFun
06 Dec 2012 17:07 - 06 Dec 2012 17:09
#561716
So far, I think I may have a good plan for the external alternator. Just need to find a guy who can TIG weld aluminum well. I also spoke with a local motorcycle shop the specializes in vintage bikes and has an excellent rep. They will be nahdling the main engine work including machining, inspection, etc... I can actually do this except for the machine shop work myself, but figure with my job and everythign else, just farm it out to these guys as they are very meticulous.
www.bluecatmotors.com
I also made up my shopping list for the engine build which I have attached below. This is incase someone else is building a similar engine, all the P/N's are provided along with vendors. Note, one page is the ZRX engine build, so pay not attention to that.... heheh
Cory
1976 Kawasaki KZ900
Last edit: 06 Dec 2012 17:09 by NakedFun.
  • WY Cowboy
  • WY Cowboy's Avatar
12 Dec 2012 15:45
#562659
Hey Cory,
I have been following your thread and have enjoyed/learned a
lot. Thanks for all of your great detailed questions and posts. I am in Minneapolis and saw you are looking for a good tig welder, attached are a couple of pictures a local guy that did my swingarm. He is 100% mobile and will come to your location. PM if you would like his info.
Cheers
Rick
  • WY Cowboy
12 Dec 2012 15:49
#562660
Hey Cory,
I have been following your thread and have enjoyed/learned alot. Thanks for all of your great detailed questions and posts. I am in Minneapolis and saw you are looking for a good tig welder, attached are a couple of pictures a local guy that did my swingarm. He is 100% mobile and will come to your location. PM if you would like his info.
[attachment:3]C:\fakepath\KZ 1000 005.jpg[/attachment]
[attachment:4]C:\fakepath\KZ 1000 002.jpg[/attachment]
Cheers
Rick
12 Dec 2012 16:42
#562668
Attachment picpostnewsite912x671.jpg not found
Good Fortune! :)
  • NakedFun
12 Dec 2012 18:44
#562681
Hey Rick,
I appreciate the info and shoot you a PM. I'll need a good TIG'er for the external belt drive components. I'll shoot you a PM.
Cory
1976 Kawasaki KZ900
  • WY Cowboy
12 Dec 2012 19:24 - 12 Dec 2012 21:43
#562692
Hope third time is a charm. Thanks Patton for the posting information.
Attachment KZ1000020.jpg not found
Last edit: 12 Dec 2012 21:43 by WY Cowboy.
  • NakedFun
12 Dec 2012 22:42
#562716
That looks good! As a side note I am bidding on a complete gilmer belt drive Mallory ignition setup which would match awesome to my external alt drive. We'll see if I can win it since I needed a new ignition system anyway.... Any one try this setup before?
Cory
1976 Kawasaki KZ900
  • WY Cowboy
13 Dec 2012 01:05
#562739
Cory
Earlier in the thread you posted the following question:
This would still leave me with the sprockets out of alignment by .140" over 27.3" chain span. This equates to .3 degrees deflection. Is this OK?
Did you receive a response to your question or find an answer? Also what was determined about offsetting front sprocket using 25mm center spacers?
Rick
