'76 KZ900 (ZRX1200R) Build
  • NakedFun
  • NakedFun's Avatar Topic Author
Re: '76 KZ900 (ZRX1200R) Build
13 Dec 2012 01:31
#562745
Rick,
No I did not get a response on that and I have tried numerous manufacturers. Every one says to get it line as closely as possible. Personally I think it would work, but would probable accelerate the wear. Who knows by how much, but probable. Long story short, went to a 5/8" offset and milling my my rear hub .210" should bring it into alignment and leave about .140" between the chain and frame and chain and tire. I decided against the spacer only due to the loss of spline engagement for the sprocket.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • NakedFun
14 Dec 2012 14:53
#562956
Rick,
I have the following front sprockets if you are in need:
17 tooth - 3/8" offset - 530 Chain
17 tooth - 5/8" offset - 530 Chain
Let me know.
Cory
1976 Kawasaki KZ900
  • WY Cowboy
  • WY Cowboy's Avatar
14 Dec 2012 19:12
#562987
Hey Cory,
I have already purchased a 630 chain/sprockets, although if things do not come together as planned I will let you know. Thanks for the offer and look forward to seeing the bike in person. I will get a thread going over the holiday season.
Cheers
Rick
  • NakedFun
14 Dec 2012 19:53
#562992
I had a break through regarding the external alternator drive! I figured out how to make it work and keep the starter functional! I am going to U-Pull It auto salvage in Memphis TN over the holidays to retrieve my parts. Let's just say besides a Ducati clutch slave, it will also be equipped with Ford Escort parts.....
Once I get all this figured out, will write up a tutorial with pics and post on here.
Rick,
Good luck with the thread and looking forward to seeing your build.
Cory
1976 Kawasaki KZ900
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
15 Dec 2012 13:05 - 15 Dec 2012 13:08
#563079
dadgummit man!
cory now you got me all anxious and jerky feeling :angry:
i cant wait to see what you come up with.i have always been interested in external alternator,and ignition drives and all that "borg" lookin mechanical insaneness :evil:
Last edit: 15 Dec 2012 13:08 by 531blackbanshee.
  • kzz1king
  • kzz1king's Avatar
15 Dec 2012 14:06
#563086
As long as you are getting all belt driven you may as well add a blower :side:
Home built KZ1000 turbo setup
  • NakedFun
15 Dec 2012 14:24 - 15 Dec 2012 14:26
#563089
As long as I could even find one if those Druidan (sp) blowers and get my pocketbook open far enough to pay for it!! Secondly, I got out bid on that Koenig/Mallory belt drive ignition...going for more than I can afford for just ignition even though it looked awesome! I did pick up a used Dyna S for $75 so I am good there. One reason I am OK about losing that bid is that those don't have auto advance, so their drivability on the street is a little compromised from what I hear.
Don't worry Leon, I'll take pics from the bone yard and post'en up.... You know my old Escort is at my inlaws.....hmmm
Cory
1976 Kawasaki KZ900
Last edit: 15 Dec 2012 14:26 by NakedFun.
  • kzz1king
  • kzz1king's Avatar
15 Dec 2012 17:51
#563101
I don't have the info anymore but when I was researching my DIY turbo project I run across some who were using superchargers off of 4 cylinder cars. What held meup is that I am not a machinist. I was also looking at an external charging system with it so I could run off that end of the crank. It was all beyond my redneck skills :)
Wayne
  • NakedFun
15 Dec 2012 20:43
#563121
Wayne,
You know rednecks are some of the first engineers! He'll, if it wasn't for some of that beer drinkin' inspired enginuity, NASA wouldn't be in Hunstville, AL!
I would bet they were using the Eaton blowers from the 4 cylinder Ford Super Coupe Thundrbirds. Otherwise there is the Eaton M90 from the V6 GMs like the GTP Grand Prix.
Cory
1976 Kawasaki KZ900
  • racer54
  • racer54's Avatar
15 Dec 2012 21:42
#563133
There's a funnybike that is using the M90 blower. Tried to find the article on his build but can't seem to find it.
  • NakedFun
15 Dec 2012 22:10
#563135
There are a bunch of M90's on EBay now. Turns out that is the same frame size that was used on the Super Coupes. Pretty compact and would be reasonable to make work. I have a small turbo sitting around that I could run the calcs on and see if that would work...... Hmmmm....
Cory
1976 Kawasaki KZ900
  • kzz1king
  • kzz1king's Avatar
16 Dec 2012 01:53
#563169
NakedFun wrote: There are a bunch of M90's on EBay now. Turns out that is the same frame size that was used on the Super Coupes. Pretty compact and would be reasonable to make work. I have a small turbo sitting around that I could run the calcs on and see if that would work...... Hmmmm....
Cory
Your Welcome :laugh: A lot of work but it would be cool. Would you do a draw thru you think?
