'76 KZ900 (ZRX1200R) Build
- NakedFun
Re: '76 KZ900 (ZRX1200R) Build
13 Sep 2012 11:18
What about either one of these:
www.powderbuythepound.com/BONDED_BLACK_CHROME/
or
www.powderbuythepound.com/BLACK_MOTHER_OF_PEARL/
Cory
or
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- NakedFun
19 Sep 2012 17:59
All,
I need some people as sounding boards for work that I have already done. I bought the universal DCC upper shock mounts, milled them to fit a tight radius to the frame tube, prepped the tube and burned them in. I have a good weld, but I am starting to wonder if I should lop them off and weld them in another way? Weld a stud to the back of them, drill a hole through the frame, slide them through and reburn them in on the outside like before, but weld the end of the stud to the inside tube? I could rill through the tube, into the mount and drill & tap them, then use a bolt? Am I over thinking this? Leon? Les?
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
19 Sep 2012 18:05 - 19 Sep 2012 18:07
yes you are over thinking this :pinch: ,
but,
isn't that what engineers do
man i do not think that there is any way(short of a GOD FORBID crash)that you could ever bend or break them off.
quit back tracking,
sounds like to much desk time and not enough shop time :laugh: .
you were confident enough to weld the damn things on :whistle: ,now move on to the next step :silly: .
while looking at them originally i never once thought that you would have any kind of problem with your work.
that is my .02 fwiw sir.
but,
quit back tracking,
Last edit: 19 Sep 2012 18:07 by 531blackbanshee.
- NakedFun
19 Sep 2012 18:29 - 19 Sep 2012 18:43
Well it is your fault Leon! :woohoo: I saw your posting about the top mounts from a post 6 months ago, and you showed the way the Sanctuary does it! You stated if a person mounted them the way I did, they would come off quickly without the through stud through the tube! :S
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
Last edit: 19 Sep 2012 18:43 by NakedFun.
- 79MKII
- Love Them Kaws!
19 Sep 2012 21:19 - 19 Sep 2012 21:20NakedFun wrote: What about either one of these:
or
Cory
I posted about these right after you...just noticed it never showed up. Anyway, those are awesome powdercoat colors....thanks for the links!
The Kaw List:
Last edit: 19 Sep 2012 21:20 by 79MKII.
20 Sep 2012 10:20NakedFun wrote: Well it is your fault Leon! :woohoo: I saw your posting about the top mounts from a post 6 months ago, and you showed the way the Sanctuary does it! You stated if a person mounted them the way I did, they would come off quickly without the through stud through the tube! :S
Cory
:blush: did i really state that :pinch: ?
i'm gonna have to look back and check on that :silly: .
you would have to rip the side outta the tube for it to fail the way you coped it,and welded it in.
being that close to the tube junction lends alot of support to that area also.
it'll be fine,
- NakedFun
20 Sep 2012 10:43
Thanks for the input Leon!
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
20 Sep 2012 11:19NakedFun wrote: All,
Cory
The following post may be helpful with regard to support for holes drilled through frame tubes.
steell wrote: The frame is just mild steel, and the only difficulty drilling is keeping the drill centered.
If I was going to drill the frame, I'd make a boss (a thick walled tube that extends through the frame) and braze it to both sides. That would provide strength and support to the frame and keep the hole from cracking. Like the right front engine mount plate bolt holes.
Brazing a mount to the frame would be better, if you can figure out how to move the crash bars mount a little.
Tig welding would probably be better than brazing, but the equipment is more expensive and it requires more skill.
- NakedFun
20 Sep 2012 16:53
Patton,
Thanks for the input. I am going forward with the way it is now, and will probable ad a small gusset that will tie it into the frame gusset I wleded in above it. It will be in direct line with the force vector that is be applied through the upper shock mount.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- NakedFun
20 Sep 2012 22:45
Well an unfortunate set of circumstances has caused my wife and I to swap our camping weekend and my build weekend! Ole' "HOSS" our '95 F350 Dually has a radiator leak that will need to be repaired, so it'll have to be fixed next week before we can use the RV. So that means build weekend is this weekend.... Got everything lined up, except the new header I bought won't be here in time. I'll post up pics this Sunday.
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- NakedFun
24 Sep 2012 15:09
So the weekend was mostly productive. I couldn't move any further until my header gets here so I can fab the exhaust. Got the gauges mounted, clipons put on, license plate made and added to the undertail, and an additional gusset added to it as well. I'll let the pics do some talking. I love the look and riding position with the clip ons!
Just everything sitting in place....
I went to a local supplier for muscle car/ vintage car rubber products (Metro Molded Products) and they carry in their show room a bunch of misc bushings, etc.. I found some for my exhaust hanger and the gauges. Made some of these that will bolt through the stock handle bar riser holes in the triple, and hold my gauge bushings and guages in place. Works fantastic and I love the position they are in. Not nearly as high as stock.
I made tabs for the license plate and decided to add a gusset as well.
Here is how it sat the end of the day...
What do you think?
Cory
What do you think?
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
24 Sep 2012 16:00
lookin good cory.
