DNel's '78 KZ650 Fighter Project
  • expatriate00
  • expatriate00's Avatar
Re: DNel's '78 KZ650 Fighter Project
11 Nov 2012 05:57
#557881
First time poster, new member. LOVE your bike build for several reasons. I'm the proud new owner of an '81 Kz650 LTD. I dig what you're doing with the build, the ride a little, mod a little aspect of it mirrors my Buell build that I just completed. I just got the KZ in August in trade (with a HUGE two stage Snap On rolling tool box),for an old pickup that didn't run. I have $0 in this bike except the title fees. I'm thinking of an update/cafe build, pulling the same trick you did with the front end. I haven't decided to what extent I'm going to mod the rear yet.
Good luck with your build! More pics PLEASE!
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
12 Nov 2012 14:02
#558054
when I started my project 650 10 years ago, itwas because it had dropped a cylinder. Now it is monoshocked and modern frontended and bored to 810 with GPz750 cams and carbs. It was a heckuva lot more fun the LAST time I rode it. That was two years ago because I got divorced in the middle of the final part of the build and am saving for a garage and room to work on it. Should be this spring, all I need to do is get the chain run right and the re-wire...
Good luck with the motor build, great looking bike.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • D.Nel928
  • D.Nel928's Avatar Topic Author
24 Nov 2012 01:09
#559827
Bdog wrote: when I started my project 650 10 years ago, itwas because it had dropped a cylinder. Now it is monoshocked and modern frontended and bored to 810 with GPz750 cams and carbs. It was a heckuva lot more fun the LAST time I rode it. That was two years ago because I got divorced in the middle of the final part of the build and am saving for a garage and room to work on it. Should be this spring, all I need to do is get the chain run right and the re-wire...
expatriate00 wrote: First time poster, new member. LOVE your bike build for several reasons. I'm the proud new owner of an '81 Kz650 LTD. I dig what you're doing with the build, the ride a little, mod a little aspect of it mirrors my Buell build that I just completed. I just got the KZ in August in trade (with a HUGE two stage Snap On rolling tool box),for an old pickup that didn't run. I have $0 in this bike except the title fees. I'm thinking of an update/cafe build, pulling the same trick you did with the front end. I haven't decided to what extent I'm going to mod the rear yet.
Thanks for the kind words guys!
Started to hack up the frame today. Cut off the entire rear of of the bike instead of cutting off tabs. Will be much quicker and cleaner in the long run. More pics to come soon!
'78 KZ650 Custom thingy turned turbo build
www.kzrider.com/forum/11-projects/520339...z650-fighter-project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
24 Nov 2012 15:17
#559873
bring on the pics.
  • D.Nel928
27 Nov 2012 23:05 - 28 Nov 2012 17:51
#560283
531blackbanshee wrote: bring on the pics.
I wanna make big progress before pics lol.
Ordered a ZX-6R rear wheel today, along with a 180\55R17 Tire, and a lot of steel tubing for the frame and swing arm. Hope to get it all fabbed up this weekend or next!
Last edit: 28 Nov 2012 17:51 by D.Nel928.
  • 531blackbanshee
  • Vendor
  • Vendor
29 Nov 2012 12:11
#560464
:) leon
  • 7aliveatlast7
  • 7aliveatlast7's Avatar
30 Nov 2012 18:33
#560690
dang man, you've done a lot of work here! i went a similar route as you with my kz440. got a gsxr front end on it with an '05 zx6r front wheel, but the rear was going to be far too wide, so i ended up going with a rear off a '10 ninja 250ex. it was the same spoke pattern as the '05 front wheel, and although it was wider than my stock wheel, it wasn't so wide that i'd have to extend my output gear and stress it. sounds like you're going the custom swinger route, can't wait to see how that works out!
  • D.Nel928
03 Dec 2012 18:44 - 05 Jan 2013 19:03
#561194
Little teaser of what's to come. Next update will be a big one ;)
Last edit: 05 Jan 2013 19:03 by D.Nel928.
  • uglee
  • uglee's Avatar
  • New 2da game but Tru 2this thang!!!!!
03 Dec 2012 23:31
#561248
ATTEMPTED THREAD JACKING IN PROGRESS........
Cool fighter build 1st off... With the modern upgrades can one go in the cruiser direction instead with as much success as the street fighters?? What would that be called?
  • D.Nel928
04 Dec 2012 01:30 - 04 Dec 2012 01:33
#561281
uglee wrote: ATTEMPTED THREAD JACKING IN PROGRESS........
Success is what you make it man. In all honesty this isn't really a fighter build, it might use ideas from fighter\cafe\brat, but my ultimate goal is to make it mine. I tell people I've got well over 5k wrapped up in this bike already, and it astonishes them. "I can buy a newer crotch rocket for that", and that's when I laugh. You can't buy mine... Idk if this post is relevant to what you were asking, but that's what I got from it.
This video fuels my build, if you build your own stuff you'll like it. Pay attention at 9:17
vimeo.com/49920522
Last edit: 04 Dec 2012 01:33 by D.Nel928.
The following user(s) said Thank You: bluezbike, abjake, moriarty
  • Primer
  • Primer's Avatar
04 Dec 2012 03:21
#561290
Sweet build. It looks like you have a solid vision...keep posting!
  • D.Nel928
15 Dec 2012 19:26
#563107
Alrighty, started to make the new swing arm and ran into a couple problems. The biggest is the spacers. I'm going to attempt to make the swinger just wide enough to use the stock spacers and all, or I'll have to get custom ones made. My only worry at this point is chain clearance.
