DNel's '78 KZ650 Fighter Project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: DNel's '78 KZ650 Fighter Project
28 Feb 2013 11:53
#574545
got any #'s stamped in them?
they look like mikuni vm28ss to me.
but i don't know fo sho.
28 Feb 2013 12:11
#574551
Where are pilot adjustment screws located (side or bottom)?
Good Fortune! :)
  • D.Nel928
  • D.Nel928's Avatar Topic Author
28 Feb 2013 12:34
#574554
531blackbanshee wrote: got any #'s stamped in them?
Haha good eye! They are VM28ss pumpers. Had to pay a bit more than I wanted for them, but they are great carbs that are getting hard to find. They should easily fuel my 810 kit in the future as well.
'78 KZ650 Custom thingy turned turbo build
www.kzrider.com/forum/11-projects/520339...z650-fighter-project
  • 531blackbanshee
  • Vendor
  • Vendor
28 Feb 2013 13:17
#574558
yessir they should be a real nice carb for your bike.
  • D.Nel928
02 Mar 2013 18:50
#574921
Took the carbs apart today, let them soak, and media blasted them. Ready for rebuild! Also dropped off the jugs to get honed, and ordered all the goodies to get the motor back together.
Dirty
After soaking
And blasted :)
  • 531blackbanshee
  • Vendor
  • Vendor
04 Mar 2013 10:59
#575255
they look good.
the billet aluminum o-ring sealed fuel tee's that z1e sells are a worthy investment while you are this deep.
keep us posted,
  • D.Nel928
04 Mar 2013 16:21
#575292
531blackbanshee wrote: they look good.
keep us posted,
Already on the way haha. The ones in the carbs were absolutely trashed, took no effort at all to pull them out.
  • D.Nel928
27 Mar 2013 21:30 - 27 Mar 2013 21:31
#579168
Well engine reassembly has begun, also got the frame back from the welder. It's all down hill from here!
Had to yank the studs out to get the gasket off around them. The gaskets were as hard as rock and I swear fused to the case. Thank god I learned of a 3M roloc bristle disk, cleaned it up in no time.
The only bad part is the dust and dirt in the crankcase, any ideas on how to flush this stuff out???
Nice fresh hone ;)
And a few goodies from Z1 to reassemble.
Last edit: 27 Mar 2013 21:31 by D.Nel928.
  • 531blackbanshee
  • Vendor
  • Vendor
28 Mar 2013 10:57
#579256
well being as how you did not tape the holes off before you went to town with the bristle disk :whistle: ,
prolly spray it out with some diesel in a squirt bottle and let it all run out the pan(with the pan off)then some carb clean/brake clean that will cut the diesel then re-oil it before assembly.
or,
pour atf all over it and let it run out wash with gas and then re-oil.
you get the idea wash out re-oil. :)
  • D.Nel928
28 Mar 2013 18:27 - 28 Mar 2013 18:28
#579314
531blackbanshee wrote: well being as how you did not tape the holes off before you went to town with the bristle disk :whistle: ,
or,
Case was already full of stuff from disassembly. Will probably use diesel, as it has some lubricity in case some gets left behind. Thanks for the advice, will be getting ahold of you in a couple days to get that sprocket made!
Last edit: 28 Mar 2013 18:28 by D.Nel928.
  • wireman
  • wireman's Avatar
28 Mar 2013 18:39
#579316
Botteming taps work good for chasing the blind bolt holes after you clean the crud out of the holes. :)
  • D.Nel928
29 Mar 2013 21:14
#579522
Been waiting for this day for a long time :)
She's got a fat ass ;)
