DNel's '78 KZ650 Fighter Project
- 650mod
Re: DNel's '78 KZ650 Fighter Project
06 Mar 2014 21:02
Hopefully this sorts out your issue
Glad I could be of assistance.
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- Bdog
- Sweep the leg johnny!!!
14 Mar 2014 11:52
Its been a while since I fiddled with the jetting of carbs, but I seem to recall that it wasn't to do with the size of the overbore, but the flow of air and exhaust gas. The jet kits come with stage 1 and stage 3. 1 is for adding an exhaust and 3 is for both pods and an exhaust. Get the main right and then adjust your needles with some washers. The jet kit needles weren't always great for the mid range cruising from what I recall also. They had a weird on/off kind of taper.
Brandon
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- D.Nel928
16 Mar 2014 17:34 - 16 Mar 2014 17:35
I have the 117.5 jets in right now, but haven't been able to see how they perform. Battery unfortunately decided to stop working altogether. With that said though, the bike is pretty much done for this season. I have a few little odds and ends to work out still, but I'll be riding it once the weather permits.
Next winter she will be torn apart again to get powdered and painted... and some go fast
'78 KZ650 Custom thingy turned turbo build
www.kzrider.com/forum/11-projects/520339...z650-fighter-project
Last edit: 16 Mar 2014 17:35 by D.Nel928.
- Tusch
- Bdog
18 Mar 2014 06:59
Also regarding your jetting, remember that Dynojet jet sizes and Mikuni factory jets sizes are not the same measurement. Meaning they use different numbers for different hole sizes. If you use the Mikuni juets and just buy them they are not terribly expensive. I think the rule was up three sizes for pods and three sizes for 4-1 exhaust. The mikuni jets go in 2.5 increments and that would put you at 127.5 with a factory jet to get your mixture right.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- D.Nel928
20 Apr 2014 18:19
- kaw-a-holic
20 Apr 2014 18:45
Nicely done sir. Hope it turned out the way you wanted.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- TS
05 Jun 2014 15:41
Sounds aggressive, and she is a beaut!
1982 KZ550 LTD C3
- gibson1
16 Jun 2014 21:58
where did
you get your front end.
till the end
