AHRMA Vintage Superbike Middleweight Racer
- turboguzzi
Re: AHRMA Vintage Superbike Middleweight Racer
05 Apr 2012 07:43
Hei Dd
good stuff
unless you plan to run full clipons, would keep the pegs not so far to the rear.
try indeed to look at pics of other race bikes to get a better idea
almost level and about 3-4" back relative to the swingarm axle would be a good starting point in my experience
if i was you, would turn simple iron 3/4" diameter bobbins with M8 thread, drill holes in the passenger footpeg brackets and weld them in there
good stuff
The following user(s) said Thank You: DoubleDub
- mark1122
- Keep twisting it
05 Apr 2012 10:27
keep in mind that, the bike may turn in better with more wieght on the front end. modern bikes have a fairly even wieght distribusion ,Front to rear,compaired to old bikes, wich r wieghted more towards the rear.
so , that being said, once u find where u like the pegs, error on a more forward location if needed.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- DoubleDub
05 Apr 2012 10:28 - 05 Apr 2012 12:09
Thanks guys, appreciate the feedback!
This was the photo I was looking at:
I'll move them up, though.
Started digging through the TG wonder build threads again...I've looked over so many things I must have forgotten most of what I saw. I love the tabs/ally plate idea, Turbo. I think I might borrow that.
Last edit: 05 Apr 2012 12:09 by DoubleDub.
- turboguzzi
05 Apr 2012 15:15
my contribuition to your war effort
peg position vs. s'arm axle in the famous momba 2 gpz550
marked them in red for you
BTW, the Gpz's have already modern style threaded mounting points for the pegs, so quite easy to do what i did
not too much rocket science in there, seen plenty fast guys that cut off the complete rear passenger sheet metal ears and welded a piece of 3/4" iron angle to the rear down tubes, two threaded holes, some no name rear sets and that was it.
not neat but didnt slow bike too much
your hong-kong multiple hole plates are already quite high tech comapred to what most guys do
- Gar1800
06 Apr 2012 15:14
Shes ruff, but could be really cool.
Gar
Gar
- DoubleDub
06 Apr 2012 15:21
Thanks, Gar. I figure better to do it with a rough bike than one that's mint. If it were mint I would have kept it for a rider.
- rstnick
06 Apr 2012 16:27
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- DoubleDub
27 Apr 2012 16:37
Been on the road for work, just got back in from Salt Lake.
I've been cleaning up the 28mm carbs and I keep getting this silver residue on my hands after dipping them - did they come painted on the Kz1000's? These would be the Mikuni 28's with the accelerator pump.
- DoubleDub
10 May 2012 20:15DoubleDub wrote: Been on the road for work, just got back in from Salt Lake.
Bump? This is nasty. If they are painted, that crap is definitely coming off before it goes back together.
- DoubleDub
10 May 2012 20:17
Ok, so I have done the following this week as I prep for a new gig next week:
I also added a couple of pieces 3/16" bar to the frame to brace/mount electrics to. Not showing pics as my welding was terrible, but it is my first time. The pieces are definitely in there, just not pretty.
I painted motor mount brackets, lower triple, frame. Waiting for the paint to cure and my steering/wheel bearings to arrive tomorrow evening.
Once the frame paint and bearings are done I'll start the engine work in earnest.
- turboguzzi
14 May 2012 05:02
you are a brave guy DD.... i am a reasonable welder but never weld my frame bracing myself, I always go to a TIG guy nearby.
The danger of holing a frame tube with a stick wleder is too high IMHO, even if Kawasaki used water pipe gauge in our frames
We all understand not wanting to show pics of your welding, but eventually you will have to post some pics fo your build.....otherwise nobody will believe you
TG
TG
- DoubleDub
14 May 2012 09:25
Naive or stupid are probably better words for it then.
I used a cheap flux core wire feed welder (Harbor Freight). I think with a nicer unit the welds would have turned out a lot nicer - I don't think the wire feed was very consistent, but I was fighting a crappy helmet the whole time too. Another thing to add to the things I've learned, don't cheap out on the equipment... Anyways, I'm not convinced this welder could have burnt through much, fortunately.
I'll post some pics after I break out the camera this evening. The frame is still curing (7 day wait on the paint I used) and I should be able to swap out the bearings early this week if I can find the time.
This whole thing is taking a really long time...wish I had more to post. My fear and naivety have been slowing me down (and supply of cash). But I think I should still be in a position to participate next year still as planned.
