AHRMA Vintage Superbike Middleweight Racer
  • turboguzzi
  • turboguzzi's Avatar
Re: AHRMA Vintage Superbike Middleweight Racer
25 Feb 2012 14:07
#506276
DoubleDub wrote: I have found myself getting overwhelmed with the amount of tasks that need to be tackled. So I'm going to step back and do one thing at a time. First up, the frame paint. And that has to wait for the weather to warm up some. Still ~34F here regularly and I can't paint indoors. Until then I'm going to work on cleaning up what I have and thinking things over.
Once the frame is paints I'll finish up the engine. I have just about everything planned out except the compression modifications as I'll have to do the measurements once everything is back together to determine how much I need to take everything down. At this point I'm planning on having the head and block surfaced to square them up and reduce the clearances to where I want them. I will likely be running on race gas so I'm hoping to get the compression over 11:1 if possible with the stock pistons to start with.
11:1 or even more should be doable with stock pisotns, you'd be looking at removing something like 1.6mm off the block. Pistons are going to stick out quite a bit so you should machine a slight taper, like 15 degs around the edge so they dont touch the head. checking piston to valve clearance is recommended too.
  • DoubleDub
  • DoubleDub's Avatar Topic Author
26 Feb 2012 18:44
#506525
Got the VM28's in the mail yesterday. I can't believe the USPS allowed them to be shipped - they stank of varnish when the mail man handed them to me.
I got to work trying to clean them up today - man, I have never seen carbs this bad. It's worth it for me to try and revive these as I have more time than money and was able to get them cheap. Everything seems to be there minus a few bits for the accelerator pump which I have to disable anyways.
Carbs are soaking on the grill in a warm/hot lemon juice/water bath. I have already free'd up one of the slides. Three more to go. What a mess. They deserved much better than this...
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
26 Feb 2012 19:32
#506535
the hard part will be cleaning the internal passages. thats where the sonic bath comes in.
i have drilled out the brass beads, in the passage ends, to get at the passages. then repluged the end with a lead fishing weight .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
26 Feb 2012 19:49
#506544
Oh man, I think I can smell those carbs from here!!!! :laugh:
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
26 Feb 2012 21:03
#506566
Attachment something-smells.jpg not found
Attachment a-fish-called-wanda-878340l-imagine.jpg not found
Attachment images_2012-02-26.jpg not found
Attachment gas.jpg not found
Attachment imagesCA488IWV.jpg not found
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • DoubleDub
26 Feb 2012 22:29
#506589
Yeah :S
I'm going to ruin my buddy's can of carb dip first and go from there. The boil freed up the slides some - I have to drill out the screw holding the rod in place as it's all mucked up. One I have it apart we'll see how bad it is.
One of the intake bell's is bent slightly, not enough that I'm too worried about it but it annoys me - has anyone ever successfully straightened them out? If so, how?
  • DoubleDub
31 Mar 2012 22:27 - 31 Mar 2012 22:32
#513284
Carbs are apart and soaking. Will take quite some time....
Did some cleaning on the block exterior, still needs some more.
Started sanding on the frame. Cut off the kick stand bracket to get it out of the way.
Got the oil pan off, pretty clean other than some sludge.
Ordering a Gpz oil pan and cooler from another member along with some Gpz cams
Hope to have some fun photos soon. once the frame and swinger are painted.
Need to take the block and head in to get them surfaced and cut down the block a little. Still need to measure clearance (once the higher lift cams get here) and compression.
Last edit: 31 Mar 2012 22:32 by DoubleDub.
  • DoubleDub
01 Apr 2012 14:29
#513388
Feel like I'm finally getting something done. Started tossing broken/unneeded parts and freeing up some room in the garage (cracked points cover, parts that won't be used or sold, etc.).
Still need to take the 750 motor apart.
Got the top triple clamp and brake stay painted with the first few coats of VHT Chassis and Roll Bar.
  • DoubleDub
01 Apr 2012 14:30
#513389
Cases are separated, went pretty smooth once I found the last few bolts I forgot :whistle:
I'm constantly amazed at how much my patience and care has improved as I work on bikes.
  • DoubleDub
01 Apr 2012 20:09
#513437
Worked on mounting the rearsets I bought.
Need to get a longer rod for the shifter linkage, possibly a bent one to get around the swingarm bolt/nut.
  • T_Dub
  • T_Dub's Avatar
01 Apr 2012 20:34
#513442
Good to see a bit of work happening. What are those rearsets from? Universal?
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • DoubleDub
01 Apr 2012 20:54 - 01 Apr 2012 20:54
#513451
Close, Hong Kong specials from flea bay for a cbr1000. I think now it would have been smarter to just get the tarozzi's as the rod has female ends unlike the tarozzis and I think I'll have a hard time finding a replacement rod to fit. The ends for the tarozzis for the male end rods are $25/each....
Last edit: 01 Apr 2012 20:54 by DoubleDub.
