AHRMA Vintage Superbike Middleweight Racer
  • T_Dub
  • T_Dub's Avatar
Re: AHRMA Vintage Superbike Middleweight Racer
01 Apr 2012 21:02
#513454
I forget what thread it was, maybe Boostable's, but he found a place to order dealies like that.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • DoubleDub
  • DoubleDub's Avatar Topic Author
01 Apr 2012 22:23
#513477
I just wish I knew what they were called... Apparently not pivot bolt, ball joint bolt, etc, etc.
  • T_Dub
  • T_Dub's Avatar
01 Apr 2012 22:29
#513479
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • DoubleDub
01 Apr 2012 22:31
#513480
Thanks, I was just digging for that...
  • DoubleDub
01 Apr 2012 23:17
#513491
Ha! Spherical rod ends! I was thinking about getting these to replace the ones on there and then getting an off-the-shelf rod from fastfromthepast, they're only $8 and have a lot of options.
Spherical rod ends: www.midwestcontrol.com/part_family.php?id=8
Fastfromthepast Rods - Curved: www.fastfromthepast.com/servlet/the-Rear...sh-Curved/Categories
Fastfromthepast Rods - Straight: www.fastfromthepast.com/servlet/the-Rear...-Straight/Categories
  • T_Dub
  • T_Dub's Avatar
01 Apr 2012 23:40
#513497
Yeah having more rod options is nice.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
02 Apr 2012 07:24 - 02 Apr 2012 07:45
#513530
they look pretty nice. B)
use your imagination, i'm sure u can make them work. :)
just google Heim joint. $3 each.
www.speedwaymotors.com/Standard-LH-Male-Heims,7306.html
www.syzbearings.com/newEbiz1/EbizPortalF...5&time=1329290199121
i have a spare set here , and i have some alum mounting plate material if u want some.
u could also just get alum rod. drill and tap the ends and use the ends that u have.
Or, rather than bending a rod, u may be able to space the ends over with a bolt, or 1 of these spacers.
www.speedwaymotors.com/Rod-Ends-Heim-Joints-Sleeves.html
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 02 Apr 2012 07:45 by mark1122.
The following user(s) said Thank You: DoubleDub
  • DoubleDub
02 Apr 2012 15:37
#513605
Thanks Mark. I couldn't figure out what the joint was called, so that's very helpful.
The rearsets are nicely done. The backing plate is completely threaded except for two of the holes so I can move the rearsets around on the plate to fine tune the location.
I need to come up with some "sleeves" to weld into the rear peg ears, I don't trust it much without something like that to add some rigidity/support. Anyonoe have any leads? I think the bolts will be M6 or M8 that would go through them, don't need them to be threaded.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
03 Apr 2012 18:02
#513848
DoubleDub wrote: Thanks Mark. I couldn't figure out what the joint was called, so that's very helpful.
i would mount them and stand on them before making that decision. it is not normal to need an added support. but since these r not normal, i will leave that to u to judges. after all, it is your bum on the line. :)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • DoubleDub
03 Apr 2012 19:26
#513864
Thanks, Mark. My concern is that the back side isn't a flat surface for a nut to sit flush on. Maybe I can come up with a simpler solution to provide that shoulder surface.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
03 Apr 2012 21:09
#513877
i'm not sure what u mean? judging by where u have it mounted in the pic.it looks like it is back too far?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • DoubleDub
03 Apr 2012 23:54
#513908
I'll grab a photo of the spot I'm concerned about tomorrow. I can't say for sure, but I think I'm happy with the pedal placement right now. I have a photo of a vintage WERA Kz650 running the pegs in a similar location. We'll see. I might move them forward still.
