Z1R Custom
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Custom
21 Feb 2011 17:42
#432549
are you going to use the z1r fairing? B)
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Custom
21 Feb 2011 17:50
#432554
are there any major differance as far as mounting points for bodywork between kz and z1r frame? B)
  • les holt
  • les holt's Avatar Topic Author
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 17:52
#432555
Yeah, I'm using all the Z1R body. The big issue with the dash is haveing no speedometer, no drive for it. Been looking at using an programable speedometer and haveing it modified to look like the original. I'm open to sugestions on this one.
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 17:56
#432558
There is some minor differences with the sidecover mounting but not an issue. The major difference is in the backend where the tail section mounts and seat latches plus the seat rail mounts.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Z1R Custom
21 Feb 2011 17:57
#432560
You'll be fine...
If it helps, due to short width of FATBARS, only had to fab a fluid reservoir brace off the head light arm mount.... Not a big deal really...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Custom
21 Feb 2011 18:02
#432562
i had the chance to buy a 78 z1r frame a while for $300 with a title,but at the time i figured id have a small fortune into it just to make roller.
i guess ill wait and see if my kawasaki ad on craigs list gets any bites! :laugh:
  • rslingshot
  • rslingshot's Avatar
Re: Z1R Custom
21 Feb 2011 18:53
#432571
I have seen a few frames raked like that and they all turned out nice. Very nice build you have going on,keep up the good work.
  • testarossa
  • testarossa's Avatar
Re: Z1R Custom
21 Feb 2011 19:58
#432583
Pass the popcorn. The bike is lookin good Les.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
22 Feb 2011 03:38
#432621
Thanks for the comments. Means a lot comming from the designers of beautiful, well thought out machines. This thing is going to get ridden fairly hard so alot of parts to get sent out for treatment, Pearson getting trans, clutch basket, and crank. Larrycavan getting head. I also need to find a powdercoater to do the frame, got a local guy that doe's me a good job but he can't do the frame. I was hoping to have this on the road by june but there is a lot of work yet to do. I see me taking a weeks vacation on this thing. Stay tuned, I will be reporting progress as I get it done.
  • Old Man Rock
Re: Z1R Custom
22 Feb 2011 03:46 - 22 Feb 2011 03:49
#432623
Interesting you mentioned this now....
I was just at Autozone this weekend and up behind the counter they had the sample rack of Auto-meter brand in various sizes... Some small enough to fit into a KZ cup.
Kozo now makes a round digital meter as well... One side Speedo, the other cup Tach with indicators....
Here's some links I found in my search.... Maybe will give you some ideas. Various sizes on operations...
Dakota Digital... Nice but $$$
www.dakotadigital.com/index.cfm?ptype=re...0&mode=cat&cat60.htm
www.nextag.com/digital-speedometer/stores-html
www.acewell-meter.co.uk/Acewell%20Speedo...s/ACE-4xxx/index.htm
www.digital-speedos.co.uk/
www.jpcycles.com/search/search?Context=2...ters&Ntk=All&x=0&y=0
www.google.com/#q=autometer+speedometers...&fp=b4a69e3db245d910
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 22 Feb 2011 03:49 by Old Man Rock.
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
22 Feb 2011 04:11
#432625
I have looked at a lot of these and the autometer one seems closest to maybe on size. Problem is I would need to find someone who can silk screen or do a vinyl sticker to match the Z1R's apearance to maintain the theme I'm after. I don't mind redoing under the dash to hold them so long as it appears factory up top.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Z1R Custom
22 Feb 2011 05:52
#432640
oh yeah! :evil:
all the fab work looks great,k!cka$$ job all the way around.
the black and gold with the chrome wheels looks very nice.this should be a killer ride when you are done.
keep postin,
