Z1R Custom
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Custom
21 Feb 2011 15:01
#432488
les holt wrote:
Yes, it was done on a jig just to make sure it was right. That frame was actually 1 of the straighter frames I've worked on.
yeah they tend to be a little tweaked especially the earl ones :laugh:
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Custom
21 Feb 2011 15:08
#432489
i didnt do the welding on this one(damn battery powered heart! :laugh: )but i did most of the fab /grunt work.
this one was done at 3 degrees to clear a front mounted turbo B)
  • les holt
  • les holt's Avatar Topic Author
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 15:08
#432490
Well thank you plummen! I ground the pocket where the neck went to fit good at 3 deg rake then jigged it up, tack top, bottom other side, top again, then bottome other side. The neck is fully welded in before the gussets were added, no pics, I was on a roll. Here's a pic from the back,
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Custom
21 Feb 2011 15:11
#432491
you dont have plans/dimensions for that frame jig do ya?
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 15:13
#432493
I hadn't thought about the lower tubing braces. I may take a look at doing that. I still have the braces in the backbone to do but that may be tomorrow.
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 15:23
#432499
I used free plans off the internet for the concept and made alot of changes. I made mine to mount on my bike lift which I also built right before the jig so was able to incorperate mounting pads. I can get some closer pics If needed. I know I'm able to do a 70 in. wheelbase chassis, Longer if I turn the axle locator around. If you look at the pic you can see the mounting pads on the side of the lift. The plates on the jig are slotted so I'm able to adjust level and square each time I set it up.
  • les holt
  • Vendor
  • Vendor
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 17:31
#432542
I think I'm actually going to get to use the Z1R front fender.:woohoo:
I'm going to have to modify the mounting a great bit but after the work I've done already I think it will happen.
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 17:34
#432543
Also ended up with a good bit of clearence between tank and forks. Real happy with my decision to completely change the neck now.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Z1R Custom
21 Feb 2011 17:34
#432544
ewwwwwwwwwwwwwwwwwwwwwww... YUMMY....
Black & Anodized Gold... Sweetness.... B)
And if staying with the ZX front braking, your going to love the ZX636 front Master Brake setup.... Master has bleeder as well, makes dual disk bleeding a breeze... ;)
Stop on a dime....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Z1R Custom
21 Feb 2011 17:40
#432547
yep i like it!
  • les holt
  • Vendor
  • Vendor
Re: Z1R Custom
21 Feb 2011 17:42 - 21 Feb 2011 17:46
#432548
Oh yeah, going all ZX6 brakes, only thing is making the front brake resivor setup look close to what one would think it should be. I'm going with billet top tree and using Z1R handle bars but putting the ZX6 controls on the ends.
We've been working so much at our paying jobs lately we both played hooky today, I know I'll pay for it, I'm swamped at work, but MAN am I glad I did. It was so nice to actually spend a whole day in the shop. I even got an outlet put in the ceiling above the lift and another light. This could get addicting:laugh:
Last edit: 21 Feb 2011 17:46 by les holt. Reason: added comments
