Project 81 KZ11R
Re: Project 81 KZ11R
25 May 2011 09:52 - 25 May 2011 09:53
a throttle housing off a 77/78 kz1000 would give you not only the throttle but the starter button and kill switch as well.should be easy to find.
not to mention it fits the ujm look.
Last edit: 25 May 2011 09:53 by 531blackbanshee.
- jydog
25 May 2011 11:59
Sorry im new here. UJM look?
531blackbanshee wrote: a throttle housing off a 77/78 kz1000 would give you not only the throttle but the starter button and kill switch as well.should be easy to find.
81 KZ1000 LTD
Griffin GA
Griffin GA
25 May 2011 18:00jydog wrote: Sorry im new here. UJM look?
universal
japanese
motorcycle
- jydog
25 May 2011 20:21
UJM. I see, says the gasshopper. New problem.. my 05 636 forks n triple just came in and i noticed somthing I havent seen here or on the customfighters site. The steering stem on the 636 and the 81 kz1000 are the same length. Instead of pressing the stems out and swaping would it be possible to turn the larger 636 down on a lathe to accept the kz stem bearings? and re-thread the end? Look at the pic and tell me if this has been done before.
81 KZ1000 LTD
Griffin GA
Griffin GA
26 May 2011 10:31
as long as there is sufficient wall thickness left you should be fine.you are going to lose one set of threads on the o.d. so that will have to be addressed as well.
i have been thinking about this myself.
- mark1122
- Keep twisting it
26 May 2011 18:00 - 26 May 2011 18:02
i'm all for doing things the easy way. i say do what leon did in the link i posted. bore zx stems base, cut off the zx stem and press the kz into it. done. no threads to cut
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 26 May 2011 18:02 by mark1122.
- jydog
04 Jun 2011 08:23mark1122 wrote: i'm all for doing things the easy way. i say do what leon did in the link i posted. bore zx stems base, cut off the zx stem and press the kz into it. done. no threads to cut
Yeah, being done that way right now. I always try to think outside the box a little but usally end up not re inventing the wheel.
81 KZ1000 LTD
Griffin GA
Griffin GA
- jydog
08 Jun 2011 09:50 - 08 Jun 2011 09:52
Anyone know what handlebars are closest to matching this BMW concept bike? Looks like some sort of fat bars with a low rise and just a small pull back. I've been looking all over the net trying to match this setup. I plan on taking a lot of styling cues from this concept bike.
81 KZ1000 LTD
Griffin GA
Griffin GA
Last edit: 08 Jun 2011 09:52 by jydog.
- testarossa
08 Jun 2011 10:03
jydog, those look like superbike bars. The bend might be a little more shallow on the BMW, but it's close. You might also try looking at some of BMW's production models to see if the same bars are used on an actual bike. If so, then you can buy the actual bars from them, but I bet they won't be cheap. I have some old dirtbike bars on my bike that are very similar.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- jydog
08 Jun 2011 20:20 - 08 Jun 2011 20:22
Thanks testarossa, I'd be happy with the bars like the one you have on that bike. My parts are back and put the front end on without bearings to see what it would look like. Not sure about the gold forks now, dosent seem to go with the chrome rear. I'll swap out parts later to get it color cordinated. Either the back will have to go black with a matching zx10 wheel or the front will have to be swapped out with some silver forks. Sombody gave me some unidentified seat foam that I stuck on it too see how it looks and its kinda growing on me. It kinda has a little kick tail to it. Feel free to me some feedback or ideas.
What do you guys think about jet hot coating the headers? Anyone done it? How much would it cost? What headers do you think I have?
81 KZ1000 LTD
Griffin GA
Griffin GA
Last edit: 08 Jun 2011 20:22 by jydog.
- mark1122
- Keep twisting it
08 Jun 2011 20:46
i didnt like the gold forks on mine either so i just painted them black. i love the polished arm.
we need a better pic of the header to help with an id.
Attachment bestrtside3.JPG not found
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
09 Jun 2011 10:22
a quick spin in the lathe would have them legs polished right up.i think someone could probably do it without disassembling them if they was careful.
i like the polished swinger and rear wheel and would strive to polish the front end and wheel to complete the look.
