Z1000R and Z1000J - Lots of pics, and Gun-Kote oven baked paint.
- RoyNor
Re: Z1000R and Z1000J - Lots of pics, and Gun-Kote oven baked paint.
17 Feb 2009 10:33
How much is to much...
Using the epoxy as a coat.
I guess I could spray layer after layer with coat on the carbon, but since this is not any side panel cover, or a little detail, I finally stopped.
In order to be able to airbrush the resin it is thinned out with thinner.
You can also use alcohol.
Since its cold where I worked, I had to go around 30% with thinner.
First I mixed the resin and hardener, and then the thinner.
You loose strength when using thinner in the resin, but that is not any big deal, its more then enough strength for this use.
Using airbrush. Also using this for Gun-Kote.
Here is the joint, non visible on the behind. Its a little overlay, 1 cm or something.
I think this is enough clear coat, I could airbrush for hours... :woohoo: :woohoo:
- kano
- Not Another Bloody Limey!
17 Feb 2009 10:45
looking good roy.
- mark1122
- Keep twisting it
17 Feb 2009 11:54
Nice job, Roy.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Kaw
- Flying Squirell
21 Feb 2009 09:01
Brilliant!
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- RoyNor
23 Feb 2009 14:53
Thanks boys.
Since I have chopped off the left side of the swing, the old needle bearing is to wide, so I need to go down 5mm, from 25mm to 20mm, but thats not a problem,
>This UK company <
They got all kind of bearings and sleeves.
>This UK company <
- RoyNor
26 Feb 2009 09:28
Sprocketcarrier.
531blackbanshee just sent me pictures of my sprocketcarrier, he is just done with it. :woohoo:
Thanks buddy. :laugh:
Here is before:
And after:
Here is before:
And after:
26 Feb 2009 09:32
glad to be of assistance sir!happy to help.
- saxjonz
- KawboyZ
26 Feb 2009 16:57
Roynor I believe this is your project? I assume so. Wow! I see that your stuff and ideas are looking very nice. And the carbon fiber!?
I wanted to do my tail, side covers and fenders as well from that material yet have no experience with that. Saw they have some body wrap that can be designed any way you want it. Adhesive on one side but that costs more to do than actually painting the body parts to look like carbon fiber.
I wonder.... what would be the feasibility of covering the tank, side covers and tail fin with a thin layer of carbon fiber and making it look like it grew there. I much like the look of carbon fiber and think that along with black and chrome it would look very sharp.
Other question that I have is that the heads and swingarm you have in the picture looks like they are anodized. How durable would the head be to all the heat that comes off of it. I have the half moon anodized gasket parts that fit with the cam cover on my bike and they have faded in less than a summer's worth of ride. I have never seen anything done like that on parts that get so hot. I hope it works great for you!
79 LTD B3
- mark1122
- Keep twisting it
26 Feb 2009 17:21
Thats what i did to mine as well. i regret it somewhat. i did it so i could keep the rim centered.
it forced me to use a 170 tire instead of the 180.
I will try going back to the stock hub and fitting a 190 tire next time i nee a new tire. This will force me to run the rim to the right but i'd like to try it anyways. I just love the look of those big ass tires.
Again, nice work ROY.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
27 Feb 2009 09:37 - 27 Feb 2009 09:38
saxjonz,roy used a product called gun kote for the gold.it is a sprayed and baked on finish.similar to powdercoat,hopefully these motors won't get hot enough to effect it.i am sure after he recovers from yesterday's concert,and the swelling in his head goes down enough to type he will reply to your q's.:laugh:
Last edit: 27 Feb 2009 09:38 by 531blackbanshee.
- saxjonz
- KawboyZ
27 Feb 2009 13:50
Thanks Banshee, I really like the looks of that stuff and maybe its just the pic but it really looks anodized. I think he is going to have a killer looking bike when he is done with it.
79 LTD B3
- RoyNor
28 Feb 2009 13:15
mark1122 wrote:
Thanks Mark.
Its a pain in the ass that centering question, I reckon with this milling I can come very close (in fact straight on) to centering and still use the original tire...BUT, as we know, its hard to do measurement when the parts not fit together properly.
It all will reveal when its machined to fit. :dry:
And as 531blackbanshee says, he is riding with the rear tire a little out of center, and doesnt notice any problems.
Wonder if there are (any?) new bikes with a offset rear?
Leon: It was a great concert.
:woohoo:
Here is the band for those who might be interested:
here is the band for those who are interested
Saxjonz:
Thanks for liking my project.
I am using Gun-Kote, thats oven baked paint that will hold 300 degrees Celsius after its been cured in the oven.
Its curing time after I have sprayed it on its approx 1 hour in the oven with something around 160 degrees Celsius.
Its a very thin paint, and its also dissipate heat, that I think is very interesting.
Its a lot about it the previous pages somewhere.
Here are some from the Homesite Gun-Kote:
Gun Kote and its uses:
1. Exterior of weapons (including clips) of all types from handguns to G5 and G6 heavy artillery.
2. Engine blocks and heads to dissipate heat.
3. Engine water jackets and water pumps to act as a barrier between dissimilar metals.
4. Protection from corrosion while helping to transfer heat and coolant.
5. Transmission cases and rear end housings to transfer heat out of the housings and when used with Gear Kote and Engine Gard Oil Treatment will result in an average 35% reduction of heat.
6. Radiators, Oil and Transmission Coolers, to dissipate heat by 8% to 10% faster then bare metal while providing excellent corrosion protection.
7. Brake Calipers, to provide heat dissipation, corrosion protection resulting in longer life.
These are just some of the applications of Gun Kote. You are limited only by your imagination!
Thanks Mark.
Saxjonz:
