Z1000R and Z1000J - Lots of pics, and Gun-Kote oven baked paint.
- RoyNor
Re: Z1000R and Z1000J - Lots of pics, and Gun-Kote oven baked paint.
24 Jan 2009 05:16
cnyl wrote:
:woohoo:
Hehe, I thought it would be nice with some chopper forks!!!
(this is the first and last time "chopper" will be mentioned in this thread!!!:blink:
Maybe I should check better on THIS SITE first. :blush: :blush: :blush:
RoyNor wrote:Thanks Calhoun.
Well, the bike looks still pretty much like an frame with an engine on, hehe.
But slowly, I am working on the the details!
Today i sent the sprocket carrier to MR 531 blackbanshee, he will mill the carrier down a few mm. :woohoo:
I do not know the ground clearance after everything is mounted up, maybe some other here knows?
But here is an old pic with the length of the fork, from center bolt to top of the fork.
284.46 inches?
That would be some long forks.. 23.7 feet you should have plenty of ground clearance..lol :laugh:
- RoyNor
24 Jan 2009 05:56
531blackbanshee wrote:
Thats sad, Øhlins are nice shocks...
Maybe you should try to get hands of some zxr shocks, they shouldn't be that expensive if you find them used somewhere, if they fit better then...
I think they have a nice quality.
yes i still need to get some decent replacements for the z1r.my re-painted stockers look ok and work ok but i would like something a little better,the ohlins i have the spring is too big around and bumps against my 200mm rear tire.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
24 Jan 2009 09:38
:laugh: :laugh: Yes that is a lot of clearance!! :laugh: :laugh:
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- RoyNor
29 Jan 2009 12:12 - 29 Jan 2009 12:25
Last edit: 29 Jan 2009 12:25 by RoyNor. Reason: fandenshelv...tabbe....
- RoyNor
29 Jan 2009 15:29
And before I forget it:
I made the blueprints with this program, in the free version its more then enough for to make these drawings;
Google SketchUp 7
Google SketchUp 7
- PLUMMEN
29 Jan 2009 19:14
allright i downloaded it now how do i use it?
:ohmy: :huh: :dry: :blink: :blush: :S :woohoo:
- Z1109R Fin
30 Jan 2009 01:01
PLUMMEN wrote:
SketchUp 7 manual now only $99,99
allright i downloaded it now how do i use it?:ohmy: :huh: :dry: :blink: :blush: :S :woohoo:
Z1000R ´83...Slightly modified...
- RoyNor
30 Jan 2009 02:58
I use the template:
Product Design and Woodworking- millimeters
And the first I do is to get a large tool bar on the right side:
View --> Toolbars --> Large tool set
I found some tutorials for you:
One training video
Another Training video
You just have to play around, and not get angry...:laugh:
Sooner or later it will come to you.
One training video
30 Jan 2009 07:08
"You just have to play around, and not get angry...
Sooner or later it will come to you."
:laugh:
now roy you know plummen only has one typing finger:P ,so for him to "play around with it"may take a while :blush: .
roy,does the block need that dowel sticking out the side like the picture?
what are the dimensions for the block ?
:laugh:
- RoyNor
30 Jan 2009 08:34
Hehe, well, I guess he needs to sharpen the pointing finger now, but that program looks very difficult, but when you first hit the breakthrough.... :laugh: :laugh:
There is no need for the dowel, I or you can make a hole, and I use a bolt there, and the size for the block is something around 30mm X 30mm X 30mm. Thats up to you, what you decide is best.
30 Jan 2009 09:40
ok,so does the block need to be machined as one with the bottom plate?
- RoyNor
30 Jan 2009 09:43
No, its no need for that.
A nice weld? or?
A nice weld? or?
