Building a GPZ1150 from a CSR1000
  • otakar
  • otakar's Avatar Topic Author
Re: Building a GPZ1100 from a CSR1000
19 Jul 2008 11:21 - 19 Jul 2008 11:23
#227071
This is JB Quick if you are not sure of what I am speaking of. JB is a Quick setting iron filled epoxy which is quite good by itself but too runny to use for the actual bonding.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 19 Jul 2008 11:23 by otakar.
  • otakar
19 Jul 2008 11:26
#227072
Next, the brackets are permenantly attached with a more substantial E-poxy paste which is also metal filled and slow setting for a much better and permenant bond.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:28
#227073
I used E-Poxy putty for this job which stays in place and will not run or droop. This is some good stuff.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:30
#227074
The bracket after it is fully filled and gusetted by e-poxy.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:31
#227075
A last picture of all brackets in place.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:35
#227077
Now a bit about the custom LED tail light. The unit was built from a truck tail light, and adapted to fit the oryginal KZ lense and housing.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:36
#227078
More detail of the unit.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:39
#227080
Another shot of the comparrison of the stock back plate and the adapted plate.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:40
#227081
One more.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:42
#227082
This shows the housing in place inside the oryginal KZ lens.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:43
#227083
All put together and eluminated.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
19 Jul 2008 11:45
#227084
Now let's put it on the bike and see what it looks like.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
