Kiwi GPZ 06 Jun 2022 15:09 #868384
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
  • Thank you received: 250
Oh sorry bout that, the name is, tetsu_gpz1100 on instagram.
Last edit: by kzstreetfighter71.
Kiwi GPZ 07 Jun 2022 00:38 #868397
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1797
Larriken something you may want to bear in mind when setting your chain tension - a friend had a GSXR /Bandit motor in a Harris Magnum that was made for a KZ motor, because of the increased distance from the gearbox sprocket to the swinging arm pivot he had to run the chain a little looser than normal to avoid breaking it !
Kiwi GPZ 07 Jun 2022 01:21 #868398
  • larriken
  • larriken's Avatar Topic Author
  • Thank you received: 61
I hear you on that one. His bike is seriously cool bit of kit. I have been following him as well. Japanese GPZ11's are a massive favourite of mine.
Kiwi GPZ 07 Jun 2022 01:31 #868399
  • larriken
Good call. I had been pondering that. The distance from the front to rear sprocket is the same as my 98 Bandit 1200 but the GPZ has an extra 30mm from swingarm pivot to front sprocket. I guess if you hit a massive bump and compress the suspension you would tighten the chain. There is a lot of clearance under the swingarm but I would hate to find out the hard way! Will back it off once I get the beastie going and see how it all goes.
Kiwi GPZ 07 Jun 2022 02:09 #868400
  • kzstreetfighter71
I like the way he has dropped the front fairing by about 50mm it breaks the flow of the lines but adds an aggressive stance to the bike and the colour is Mazda "soul red crystal metallic" just love that red.
Kiwi GPZ 07 Jun 2022 02:26 #868401
  • Wookie58
  • Wookie58's Avatar
  • Moderator
I would suggest taking the spring off and check the tension through the entire travel of the swingarm (I believe the longest point is when the swingarm is level)
Kiwi GPZ 07 Jun 2022 07:28 #868408
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2071
Definitely. The greatest length between sprockets occurs when the output shaft, swingarm pivot and rear axle are perfectly in line. As the end of the swingarm moves a way from this alignment (in either direction) the distance between the sprockets decreases. Something else to watch for is the chain hitting something else, especially the swingarm pivot tube. When checking for clearance, be sure to check the chain loos and tight on both the upper and lower run. Check at both extremes of travel as well as with the three points lined up. Also check with the chain guard in place.
Kiwi GPZ 07 Jun 2022 07:47 #868410
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 266
Fellas, there is more than 1 way to skin a cat! One of my mentors designed and built stationary chain tensioners.... when needed the tensioner would take up the slack. When not needed the chain came up off the tensioner. See below pic right behind countershaft sprocket.
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
The following user(s) said Thank You: Skidmark, Wookie58
Kiwi GPZ 07 Jun 2022 08:19 #868413
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
That is a cool tracker!  I happen to be building a tracker out of a Suzuki LS650 Savage at the moment.  I am going with a similar blue, but the frame and components will be metallic silver.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Kiwi GPZ 07 Jun 2022 10:40 #868419
  • TexasKZ
  • TexasKZ's Avatar
  • Away
There be many ways to skin that cat. Type chain tensioner roller on swingarm into your favorite search engine.
Kiwi GPZ 07 Jun 2022 14:03 #868433
  • slayer61
  • slayer61's Avatar
Not sure I follow your meaning TKZ? Sure... anybody can buy a spring loaded chain tensioner from china or amazon. My point was you have options for keeping slack out of your chain. It doesn't have to be loose and or floppy.
Kiwi GPZ 07 Jun 2022 18:08 #868460
  • TexasKZ
  • TexasKZ's Avatar
  • Away
I do appreciate the creativity and skill it took to create the device pictured above. I was just pointing out that there are options for folks who cannot or would rather not go that way.
