Which one do you prefer?
  • wireman
  • wireman's Avatar
Re: Which one do you prefer?
31 Aug 2012 00:43
#545811
ramtough_63 wrote: Ok this is Just a quick Photo Shop but you get the idea
replacable inserts Carbon Fiber Chrome Words Matching paint colors the sky is the limit
Attachment 100_5735.JPG not found
Thats what I was thinking,or even clear lexan or something like that to add strength but you could still see through it. B)
  • kaw-a-holic
  • kaw-a-holic's Avatar
31 Aug 2012 01:00 - 31 Aug 2012 01:45
#545815
Okay Les, everything was pretty straight forward. So before we get started let me say this. I know that you want this to be an easy bolt on kit but.....home mods are still required.
1. Stock brake line is to long.
2. New master cylinder reservoir has to be mounted.
3. Brake light switch. (recommended banjo bolt with built in switch probably easiest solution).
Here are the before and after shots. Keep in mind this is a rough install. The only issue I had was I used the stock washers from my original pegs and had to grind them down so the would not get stuck in the mounting bracket.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: 31 Aug 2012 01:45 by kaw-a-holic.
  • les holt
  • les holt's Avatar Topic Author
  • Vendor
  • Vendor
31 Aug 2012 07:14
#545848
I used the same brake line and was fine, but I also had a ZX cylinder mounted in the stock KZ location. Never mentioned reservoir, guess I figured it was a given there. The depth of the pocket for the nut puts the nut flush without using a washer, Just used the serrated nuts.
I'm betting you'll have to lower the shifter from that position. I did, I'll get a pic up this evening of the angle of mine.
Thanks
Les
  • kaw-a-holic
31 Aug 2012 11:34
#545870
The angle of the shifter works great. I found that between the adjustments I can make on the shift linkage and the angle of the linkage lever you can get the shifter arm to sit where ever you need it. Mine is sitting at the same angle as the brake lever.
I used my stock shift lever and cut it down drilled and tapped it to connect the linkage. Eventually I will get the ZX900 linkage lever in there.
Jon
1977 KZ1000a1
Mesa, AZ
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
31 Aug 2012 11:45 - 31 Aug 2012 11:47
#545872
freakin sweet man!
kudos for re-using the stock lever kaw-a-holic.
a machined out bung (les :whistle: )drilled and tapped would make re-purposing the cutdown stock lever very nice.
it would require some welding and would kinda spoil the "bolt-on"deal but is well within reach of many kzriders.
i wish i had the dough,i would be all over these.
LOVE'EM LES !
yeah,i hollered :laugh: .
p.s.my idea is a series of descending size holes in the webs
for -
a- lightening (like they need it :whistle: )
b- style
c- keeps the strength.
Last edit: 31 Aug 2012 11:47 by 531blackbanshee.
The following user(s) said Thank You: kaw-a-holic
  • kaw-a-holic
31 Aug 2012 11:51
#545873
They look so nice! This winter when the bike gets torn down for polishing and paint I will make them sparkle. Since I am going with green pinstripes and accents I decided to paint the insides of the levers green.
Jon
1977 KZ1000a1
Mesa, AZ
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
31 Aug 2012 12:23
#545876
531blackbanshee wrote: freakin sweet man!
not sure what u mean Leon?
for -
b- style
Thats what i first thought too.
then i thought , why not shape the hole pattern into KZ, or something to your liking.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • Vendor
  • Vendor
31 Aug 2012 13:18 - 31 Aug 2012 13:28
#545885
for -
b- style
i would opt for a bung(machined out slug) 3/4" od x .500 width(or 1/2" od x .250 width whatever "fits/looks")the best ,with a threaded hole that matched the hardware for the linkage in the center.
then just trim your stock shifter to length (like kaw-a-holic did) and weld the threaded bung on the end for the linkage to bolt to.
voila,custom splined linkage that,
a-fits the splines
b-fits the linkage/bolt
c-fits the look
d-and is nicely finished.
you savvy ? :whistle: :lol:
sav·vy   /ˈsævi/ Show Spelled [sav-ee] Show IPA verb, sav·vied, sav·vy·ing, noun, adjective, sav·vi·er, sav·vi·est. Informal .
verb (used with object), verb (used without object)
1. to know; understand.
cutting kz or some such out in it while appealing to certain people,seems a little tooo o.c.c. for me.
cutouts and lightening holes are strictly "race sh!t dog" :woohoo: ,which directly translates to these old muscle bikes :evil: .
cutting kz or some such out seems a little chopperish,imho sir.
in my defense i'm a form follows function kinda guy and doing something for the sake of having a little more "look at me" effect is usually not my first urge.
don't get me wrong i like to peacock around sometimes :silly: .
Last edit: 31 Aug 2012 13:28 by 531blackbanshee.
  • Je77ekz1000a
  • Je77ekz1000a's Avatar
31 Aug 2012 13:54
#545887
Kaw-a-holic,
I see you still have your kick starter, as do I. Are these rear sets gonna allow us to continue using it or does it render it useless?
Jesse Shasteen
77 KZ1000 A
Huntsville AL
  • NakedFun
  • NakedFun's Avatar
31 Aug 2012 14:04
#545888
Les,
Did your distructive testing show anything on the skeletonized set? Also, will do my full mock up with the stock studs on Tuesday and document everything for you. I have O rings and bolts coming in from Fastenal. Also, found some aluminum tubing that I will be using as a sleeve to make the current Gen work with the bolts.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
31 Aug 2012 14:38 - 31 Aug 2012 14:51
#545891
i agree with u as usual Leon.
but but my eye's likes a little bling too. :)
and a proprely shaped hole pattern can look like eye candy , and serve equally as form and function.
i have seen some swiss cheeze clutch covers that look so sweet. :)
there is nothing that looks better than when form and function come together.
someone here has a nice example of a clutch cover but i cant find it now. is it ted ???
this works for me too. its on my wish list.
Attachment yoshkzpointscover.jpg not found
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 31 Aug 2012 14:51 by mark1122.
  • les holt
  • Vendor
  • Vendor
01 Sep 2012 06:57
#546007
No destructive testing as of yet, On the hole pattern, I can do them but for some reason, even when done well, I see a young kid with a hand drill doing what the old hot rodders did to cut weight. I tend to lean towards Aarons ideas again or maybe cutting thru with KZ or Z1
On the stock shifter modded, I did basically the same thing and changed to a newer sport bike setup. More often than not the original shifters don't seem to stay tightly clamped on the shift shaft and when they move around they cause wear. Not saying it will happen to everyone. But, offering a weld on bung with instructions is a nice touch. ;)
