new gullwing triples...for modern fork conversion
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: new gullwing triples...for modern fork conversion
06 Aug 2010 05:31
#388586
i'm not understanding, why u wouldn't use the stock KZ stem? with the stock stem u would use the stock KZ bearings.
i supose its 1 less thing for the new owner to have to do, just bolt it on. not a big deal if u are making all new parts anyways.
i am just curious.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • irishwill
  • irishwill's Avatar Topic Author
06 Aug 2010 07:13
#388615
i am just curious.
the bottom and top clamp r not the same thickness as the stock clamps....I suppose u could machine the stock stem to fit....but if your going to machine it anyway....why not make a new piece?
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
06 Aug 2010 08:07 - 06 Aug 2010 08:09
#388621
I'm missing something here too - couldn't you have just made the new upper and lower clamps to fit the stock KZ stem? Maybe the stem would be too short because the new clamps are thicker? Sorry, just trying to make things right in my head...and that could take a while... :P
The Kaw List:
Last edit: 06 Aug 2010 08:09 by 79MKII.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
06 Aug 2010 08:30
#388624
ok i get it. :)
You are absolutely right. No point trying to mod the old stem, when u can make a new one.B)
what is the fork holes diameter?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • irishwill
06 Aug 2010 09:02
#388627
mark1122 wrote:
ok i get it. :)
the measurement at the top of the forks is 50mm....and the lower clamping Dia. is 54mm
but the trouble you will have is the spacing between forks....you will probably have to space ...for the wheel and caliper rotor ...being a different brand....I dought they all ahve the same spacing between forks
  • irishwill
26 Aug 2010 19:24 - 27 Aug 2010 09:12
#394098
ok fellas...its done....
the first set is going to pochev14....I am going to make 6 sets....I am going to keep 2 sets so that leaves 4....I am pretty sure I have a set sold...so 3
anyway the best I can do is 600...which will include a head light bracket and bar clamps...as well as the upper lower and stem.
if they all sell I will consider doing another 6 (a 12' piece will make 6 sets)
also I have been approached to build a complete roller for a fellow cannuck...so if that transpires you will see that as well....mr cavanaugh has already been contracted to build the head....so you know it will make some ponies.
as always first come ...you know the rest.
were gonna make the world cool again....one bike at a time!
later boys
Last edit: 27 Aug 2010 09:12 by irishwill.
  • porchev914
  • porchev914's Avatar
26 Aug 2010 22:49
#394129
That is effing awesome. There are just no other words for it.
FRANKEN Z!
  • COE1948
  • COE1948's Avatar
26 Aug 2010 23:51 - 26 Aug 2010 23:52
#394134
Hello Ben will the new triples fit ZZR 1000 fork tubes
Regards Dale
1x1973 Z1900,2x1974 Z1A900,2x1975 Z1B900,2x1976 KZ900s & 2x79KZ1300
XS1100 Yamaha solo
XS1100 Yamaha with DJP sidecar
FJ1100 Yamaha
Last edit: 26 Aug 2010 23:52 by COE1948.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
27 Aug 2010 06:51
#394172
I've got no business even considering a set of these but they are gorgeous! Can you refresh us on what front end components they are set up for? GSXR 1000, I think? What years will fit and what parts would we need? I think the entire front wheel, brake, fender, etc... plus the forks would slide right in your triples and we'd be good to go, right?
The Kaw List:
  • irishwill
27 Aug 2010 09:11
#394235
they will fit any fork with a 50mm upper dia and a 54mm lower dia....the problem you may or may not have if you use something other than a gsxr 1000 (03-07...and im pretty sure 750 forks work as well) is the spacing between the forks...you may have to fab spacers for your wheel and also your calipers.
it may just bolt up ....i just dont know....
hope this helps
  • irishwill
27 Aug 2010 09:16
#394236
Regards Dale
not sure Dale ....Ive listed the fork dia's....if you could find out the spacing between forks....we could figure it out....Ill go measure the center to center distance and post it here in a bit
50mm top clamp
54mm bottom clamp
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
27 Aug 2010 11:22 - 27 Aug 2010 11:23
#394264
Like you mentioned, if you buy a front end from an 03-07 GSXR 1000, everything will bolt right up - front wheel, axle, spacers, fender, etc... Just put KZ bearings on the new triple tree and bolt them to your frame. Then bolt on the new front end and you're ready to go! That is well worth $600 plus you get awesome looking billet pieces to show off. If you also have it so the stock gauges and headlight will work - that is heaven!
After recently completing a custom rebuild on my MKII I can tell you for sure that customizing parts can get real tricky - and expensive. If you can avoid having to custom fit all those front end components it would be sooo much easier. Once you change one part, it leads to another necessary change, and then another, and so on. It get's crazy, as you know!
Our biggest problem will be the sudden demand on eBay for late GSXR front ends! :laugh:
The Kaw List:
Last edit: 27 Aug 2010 11:23 by 79MKII.
