new gullwing triples...for modern fork conversion
  • irishwill
  • irishwill's Avatar Topic Author
Re: new gullwing triples...for modern fork conversion
05 Aug 2010 15:40
#388433
  • irishwill
05 Aug 2010 15:41
#388435
  • irishwill
05 Aug 2010 15:45
#388436
well they are done....just a slight mod to the stem length and presto wammo finito!
they worked out pretty well....steering is just like stock...and the ride height can be raised about 5/8" ...we tried to get the whole inch but the material would have been too thin...(in my opinion)....anyways...thats what they are going to look like....
  • irishwill
05 Aug 2010 15:59
#388442
  • porchev914
  • porchev914's Avatar
05 Aug 2010 16:05 - 05 Aug 2010 16:07
#388443
No eBay APP ID and/or Cert ID defined in Kunena configuration:woohoo: :woohoo: :woohoo: Damn they look great Ben!
As far as getting the stock hight back, I ran accross these a while back:
1" fork extension caps, which would give you all your ride hight back.
Again, excellent work Ben, you've outdone yourself! They look even sexier in the video :kiss:
FRANKEN Z!
Last edit: 05 Aug 2010 16:07 by porchev914.
  • irishwill
05 Aug 2010 16:07
#388444
i just noticed the bars are crooked....i put the clamps on opposite of each other and because they are drilled offset...(so you can mount the bars forward or back) they are cockeyed....turn one around and they will be perfect! ;-)
  • irishwill
05 Aug 2010 16:08
#388446
No eBay APP ID and/or Cert ID defined in Kunena configurationporchev914 wrote:
some ones using there noodle!!
  • porchev914
05 Aug 2010 16:13 - 05 Aug 2010 16:16
#388447
Ahhhh, you video taped crooked bars.. FOR SHAME :laugh: :laugh: In light of the monumental success though, all is forgiven B)
FRANKEN Z!
Last edit: 05 Aug 2010 16:16 by porchev914.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Aug 2010 18:33
#388480
They look awesome Ben. Great work.:ohmy::cheer: :woohoo:
could we get some #'s on them? i am curious to know if other forks might fit them.
what is the fork hole diameter?
why did u need to shorten the stem? didnt u use the kz stem?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • TerryK
  • TerryK's Avatar
05 Aug 2010 20:17
#388526
Jebus Benny yer, fackin' killing me here! I'm saving my pennies for my conversion!
Amazing work brother!
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • porchev914
05 Aug 2010 20:42
#388534
The stem is a new piece designed to fit kHz bearings but use the gsxr stem hardware.
FRANKEN Z!
  • irishwill
05 Aug 2010 21:56
#388547
no we made new stems...so that we could use kz/z1 bearings ....the code got erased so we had one from before and now we know what needs to be done....just the end threads need to be moved ....not a big deal
