Speed Triple Single Sided Swingarm Installation
  • porchev914
  • porchev914's Avatar Topic Author
Re: Frame Jig and SSA Installation
20 May 2010 08:04
#369224
As for the nitrogen resevior Josh, I think I will mount it to the new lower subframe tubes, back where the passenger footpeg brackets will go. I havent decided on those yet, so the resevior mounting will wait until I have that figured out.
Mark, between screwing up ever larger amounts of my tube stock and the baby crying all the time, it was a bit.......trying :laugh:
FRANKEN Z!
  • testarossa
  • testarossa's Avatar
22 May 2010 07:04
#369758
Does your reservoir have an adjuster for compression dampning or some-such on it? Mine does. What about the hose, are you gonna be able to use the one that came with the shock? My hose is crazy long. Sorry, I had to say it. Anyway, I may have to have a new, shorter hose made :( and have the nitrogen recharged.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • porchev914
22 May 2010 11:17
#369819
Yeah, the resevior has an adjustment for compression. The rebound adjustment is above the bottom shock eye. I had thought about changing the hose, but mine isn't long enough for it to be an issue so I'll just leave it be.
FRANKEN Z!
  • porchev914
27 May 2010 18:22
#371491
With my welder fixed, I was able to weld caps on the shock mount cross tube. Not necessary from a structural standpoint. Purely asthetic-
Not exactly mind blowing progress, but thats how you eat an elephant: one little bite at a time :)
FRANKEN Z!
  • PLUMMEN
  • PLUMMEN's Avatar
27 May 2010 19:45
#371512
are you going to triangulate that mount? B)
  • porchev914
27 May 2010 19:49
#371517
Yes sir, I most definately am. I can't leave it like that :blink: That would be rather irresponsible of me :silly:
FRANKEN Z!
  • irishwill
  • irishwill's Avatar
27 May 2010 19:52
#371522
made a little progress on the trees tonight...maybe this weekend ....if Im able to get in there....Ill wrap it up
  • porchev914
27 May 2010 20:03
#371531
Ooooooooooh! What do you have left to do to finish up the triples Ben?
FRANKEN Z!
  • irishwill
27 May 2010 20:09
#371536
basically...we forgot the second mounts for the guage....so that needs to be done....and other than that just some drilling and tapping....and the cutting of the "rings" ....
  • porchev914
27 May 2010 23:57
#371576
I'm sure Pen is stoked, I know I am :cheer: Did you get her engine off to Larry C?
Onward! I got a couple braces cut and tacked in for the top shock mount. They're not symetrical though, so I'll take one off and rework it until they match. If I don't, it'll gnaw at me and I'll stare at it everytime I look at the bike :dry:
FRANKEN Z!
  • larrycavan
  • larrycavan's Avatar
28 May 2010 02:36
#371582
Just wait till you ride it....it's all going to be worth the hard work :)
  • porchev914
28 May 2010 07:26
#371621
Thanks Larry, I keep imagining the gratification I'll feel when I take her on her maiden voyage, and the bike is smooth and tight, the brakes are powerful and effortless, and the engine (after break in) will scare me a little. Thats the vision at any rate! B)
FRANKEN Z!
