Speed Triple Single Sided Swingarm Installation
  • porchev914
  • porchev914's Avatar Topic Author
Re: Frame Jig and SSA Installation
03 May 2010 09:51
#365203
EXCELLENT tip OMR, and timely! I was just looking at the best place to put the battery, and I was thinking I was going to need a gel battery. Then I thought it would be nice to have a little larger capacity, but I hadn't researched sizes yet.
Josh, don't worry about hijacking my thread, its all relevant. ;) I think that I'm going to use a pyramid cross brace for the shock mount. That way I get the strength of the 3 dimensional X, and a place to bolt my shock all in one. I also wanted to make my subframe removable, so a main frame connection for the shock works better for me than a subframe connection. Thanks for the inspiration guys, lets see where this leads.... B)
FRANKEN Z!
  • testarossa
  • testarossa's Avatar
03 May 2010 19:10
#365337
Here are the pics of the pod filters. I have about one inch of clearance to any part of the frame.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • porchev914
19 May 2010 23:16
#369170
Between the older kids and the baby, I'm lucky to get 5 minutes in the garage! So, over the course of the last two weeks I've managed to put together 1/2 of the top shock mount. Here are the brackets tacked onto the 1" cross tube-
FRANKEN Z!
  • porchev914
19 May 2010 23:32
#369173
The corner tubes are 7/8", and were tricky little buggers to fit up. I must have made 8 of them before I got them the right size and to fit. With the corner tubes mating up with the frame tubes droping away and out, it was a complex angle to attempt to duplicate. Add to that the fact that my frame is asymetrical, and I was pushing the envelope of my fabrication abilities.
FRANKEN Z!
  • porchev914
19 May 2010 23:33
#369174
oops :blush:
FRANKEN Z!
  • porchev914
19 May 2010 23:38
#369175
So with the shock mount sitting in place, it looks something like this-
FRANKEN Z!
  • porchev914
19 May 2010 23:46
#369177
Now, the top shot looks off, but I didn't take the pic centered. But more than that, the brace doesn't look centered because its not! The shock is centered in the swingarm, and the top of the shock is centered within the frame, but with the asymetrical frame, it looks a little off. All my fitment was done with a line laser to help insure congruity.
FRANKEN Z!
  • porchev914
19 May 2010 23:53
#369178
Now, I did say this was 1/2 of the top shock mount. Once I have the main mount completed (cap the ends of the tube, clean it up a bit) and tacked to the frame, I will make two diaganal braces from the center of the shock mount and up to the top tubes at the top subframe connection.
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 May 2010 03:51
#369186
That does look like it could test 1's patience pretty good.
Good work Adam.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
20 May 2010 04:08
#369187
Good work Adam. Do you have a plan on where you are mounting that remote nitrogen reservoir? That one has me stumped at the moment.
2004 ZX-10R
Angola, IN
  • irishwill
  • irishwill's Avatar
20 May 2010 04:57
#369194
hmmm....that looks familiar ;-)
nice work bud....I think you will find that you wont need to add the extra tubes...once this is all welded it will be quite ridgid....but....in the interest of making it BOMB proof... a small 90 degree gusset(made out of 1/8th plate) that sits under or over (or both) ....the short angled tubes will be lots....and will allow more room for the battery box ect.
just my .02
  • porchev914
20 May 2010 07:25
#369214
Yes Ben, it should look familiar! I agonized over how to make the top mount. It was too far away from the main tubes to use a simple cross brace, and I didn't want to brace off the subframe. Then I remembered what you did with Pens, and I pirated the idea. I hope you don't mind bud ;) I was angling toward the cross bracing to triangulate the rear engine hoop a bit, and to support that mount. There would be alot of stress on that bottom weld, and I wanted to help resist that vertical component of compression.
FRANKEN Z!
