Speed Triple Single Sided Swingarm Installation
  • porchev914
  • porchev914's Avatar Topic Author
Re: Frame Jig and SSA Installation
02 May 2010 17:45 - 02 May 2010 17:46
#365075
Damn, a triple shock single sided swingarm. Well done Josh. And here I was, making fun of Tri making fun of me :blink:
So, when I got my swingarm, I was smart enough at the time to take distance measurements of the swingarm, shock and linkage mounting points as they relate to each other from the bare frame. I am SOOOOO glad I did that. Without those numbers, I would have had to find a Speed Triple to get angle measurements off of. After figuring out that I indeed had the information I needed, I set about continuing the linkage mount fabrication. The tabs I had already cut out yesterday got cleaned up on the bench grinder. The 1.5" tubing that I had cut longitudinaly got clamped in the vise over some 1" bar stock, and hammered on until it conformed to the 1". Then I measured very carefully and tack welded the parts together. The finished product? Not too bad-
FRANKEN Z!
Last edit: 02 May 2010 17:46 by porchev914.
  • porchev914
02 May 2010 17:55
#365077
Then, with my uber important measurements in my grimey hands, I put the linkage bracket into place and began rotating the linkage bracket around the lower frame brace until the measurements all jived. Then I tack welded the brace into place and VIOLA! I now have a shock linkage mount! :woohoo: :woohoo: :woohoo:
FRANKEN Z!
  • T_Dub
  • T_Dub's Avatar
02 May 2010 18:00
#365078
Very cool Adam. Very.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
02 May 2010 18:31
#365087
Looking good bro.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
02 May 2010 18:49
#365093
Thanks guys. So now that I have the bottom done, its time to work on the top. Any words of wisdom from the veterans that have done this? I'm not talking about fabricating the mounts so much as what people have done that looks the best. So to rephrase, whats the best looking way to fab the top mount?
FRANKEN Z!
  • porchev914
02 May 2010 18:49
#365094
Here is the top of the shock, swaying the breeze :laugh:
FRANKEN Z!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
02 May 2010 19:08
#365095
porchev914 wrote:
Thanks guys. So now that I have the bottom done, its time to work on the top. Any words of wisdom from the veterans that have done this? So to rephrase, whats the best looking way to fab the top mount?
Add silicone implants and enhance the size if the nipples. then mount it as often as u like.:woohoo:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
  • testarossa's Avatar
02 May 2010 19:58
#365103
porchev914 wrote:
D
So, when I got my swingar, I was smart enough at the time to mount her. I am SOOOOO glad I did that. After figuring out that I indeed had the information I needed, I set about continuing to mount her. I had already cut out yesterday and got hammered. Then I very carefully finished her. The finished product? Not too bad- quote]
See we knew that you could mount it all along.
Seriously, how far it the center of the shock eye from the "A-frame" below the seat when centered in the hole in the swingarm?
PS all I did was edit your words here.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • porchev914
02 May 2010 20:40
#365123
:laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
3.75" from bottom of the seat rails to the center of the shock eye. What was yours Josh?
FRANKEN Z!
  • testarossa
02 May 2010 20:58
#365128
Mine is 6.5" below the seat rails and about 2.5" aft of the a-frame behind the motor. I just stole the mounting yoke from the GSXR and with a 1/4" plate welded to the back of the a-frame it came out perfect.
You are gonna have to get real creative when it comes to mounting the battery, fuse box, regulator, rectifier, etc.
2004 ZX-10R
Angola, IN
  • Old Man Rock
  • Old Man Rock's Avatar
03 May 2010 05:57
#365177
"You are gonna have to get real creative when it comes to mounting the battery, fuse box, regulator, rectifier, etc"... well that's a given in a mod no doubt...
TIP: Before copying your battery box dimensions, don't do what I did for had to re-do... Wanted larger amp hour gel battery that is 1/2" taller...DOH! :pinch: Forgot about that one so had to re-do...
Regarding the cross members, what about your carb pods, enough clearance?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • testarossa
03 May 2010 08:21
#365195
I'm good on the clearance with my pod filters. I just put my carb rack back together. I'll try to get a pic tonight. However I don't want to hijack Adam's thread.
2004 ZX-10R
Angola, IN
