Speed Triple Single Sided Swingarm Installation
- irishwill
- mark1122
- Keep twisting it
Re: Frame Jig and SSA Installation
14 Mar 2010 17:06
porchev914 wrote:
mark1122 wrote:I just took this out in the sunlight Mark. How does this pic look on your screen?Congratulations on the coming, new baby .
The bike looks great.
Is anyone else finding the pics look well lit while loading, and then go dark, after completely loaded, or is it just at my end?:S
The pic looks better, but there is definitely something going on at my end. it starts out loading very bright, then goes dark??
Thanks for trying.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
14 Mar 2010 20:24
irishwill wrote:
The custom outboard bearing support will definately push it over the edge! Did you get my payment Ben?
If this build turns out half as good as the veterans bikes here, I'll be happy!
this thing is gonna be sick!
FRANKEN Z!
- irishwill
15 Mar 2010 04:55
yes I got ot Bud....
Ill pm you the tracking # and bearing info when I get home from school
- porchev914
15 Mar 2010 07:34
No worries mate, just wanted to make sure the money went to the right place! Today I'll be working on the rear motor mounts. Not very exciting, but as the saying goes, the devil is in the details
FRANKEN Z!
- irishwill
15 Mar 2010 15:47
youve got mail bud...tracking # and such
and yes the details make or break a project...i think you have a handle on it though by the looks of things
- porchev914
16 Mar 2010 23:24
So in my last post I stated I would be working on my upper rear motor mount. Now, I got half of one made before I Effed it up. If this is the worst technical error I make during this build I'll count myself blessed by the KZ gods. The bottom line is I discovered that the top rear motor mount bushings in the frame no longer align with each other. They both angle down now. I suppose it might have had something to do with stretching the frame around that SSSA. Long story short, I tried to cheat it and wound up junking an 80% complete motor mount by cross threading one side. This is the misalignment I speak of. Can you see it? :blush:
FRANKEN Z!
- porchev914
16 Mar 2010 23:28
So, rather than attempt to fix the existing bushing, I'm going to replace them. I mean hey, I'm replacing just about everything else anyway, whats a couple more bushings. So, I picked up some 1" solid round and got to cutting on some new motor mount frame bushings :silly: Just like before, the raw on the left, the completed on the right
FRANKEN Z!
- porchev914
16 Mar 2010 23:32 - 16 Mar 2010 23:32
irishwill wrote:
Thank you Ben, that means alot comming from someone of your abilities. I'm looking forward to the bearing support. I can't use it for a while, but I'm looking forward to getting it non the less!
FRANKEN Z!
Last edit: 16 Mar 2010 23:32 by porchev914.
- larrycavan
17 Mar 2010 06:00
Oh yea....push frame apart and every formerly parallel mount point just went out of wack:S
As long as you're at it, you may as well address the 2 middle motor mounts. They're going to need spacers made up as well.
If you get the motor in position before you do the swingarm finalization, it may prove to be helpful.
Keep plugging away! I'm eager to see this bike completed.
Larry C
Larry C
- mark1122
- Keep twisting it
17 Mar 2010 06:23
porchev914 wrote:
It sounds like u have it figured out.
I just had a thought.
What if u took irishwills cross motor mount, welded a plate on each end , then drilled and bolted the plate in place. I’d bolt it to the 2 of the frames motor mount holes, just like the stock mount does.
This would be a lot simpler.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
17 Mar 2010 08:25
larrycavan wrote:
I actually had the engine bolted in the frame during the widening specifically to ensure the front and bottom mounts did not stray. Also all widening took place aft of the center mounts. I did get some 3/8 in aluminum plate for odds and ends. I'm workin on it Larry, keep the motivation comming!
Thank you Larry, it makes me feel better knowing professionals are keeping an eye on meOh yea....push frame apart and every formerly parallel mount point just went out of wack:S
Larry C
FRANKEN Z!
