kz gsx-r swap
- thane_420
Re: kz gsx-r swap
08 Feb 2010 16:39
mark1122 wrote:
here is a pic of seat pan. i cut some metal out of the seat pan and shaped pan to hug tail....you cant see much of the welds but you can see some if you look close. the tail is a early 900 tail
Nice score on the mic 29's. your bike is weet. i must join the rest and pester u for more details. lol
can u elaborate on the seat mod? i love the way it hugs the duck tail. what tail lt is that.
73 kz900 1075,mre clutch,race cut tranny,cams,airshift,34 flatslides, custom rear wheel
76 kz900LTD gsx-r suspension swap, mikuni 29mm smoothbores, stock engine
72 suzuki gt750 2-stroke triple
- thane_420
Re: kz gsx-r swap
07 Mar 2010 07:13
Some eye candy for everyone!!! Started to tear down bike again.. done this more times now than you can shake a stick at.:silly:
- thane_420
Re: kz gsx-r swap
07 Mar 2010 07:18
what i a used to space the rear wheel
tried to get a pic of the chain clearance i have a 530 chain with 1/2" offset 17 tooth
- mark1122
- Keep twisting it
Re: kz gsx-r swap
07 Mar 2010 07:57
Well done. I'm glad to see that things are moving ahead smoothly for you.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Dad
Re: kz gsx-r swap
07 Mar 2010 13:05 - 07 Mar 2010 13:06
thane_420 wrote:
Hey thane... love the bike!!! The mod to the seat is really original... hope you don't mind if I try to copy you!
And one last question... what tail light are you using?
Tone
Tone
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
Last edit: 07 Mar 2010 13:06 by Bad Dad.
- mark1122
- Keep twisting it
Re: kz gsx-r swap
11 Mar 2010 09:18
thane_420 wrote:
your right , i cant see the welds. that must mean u did a supper job on them. it turned out very good. id like to see some close ups of the tail light as well , and the under tail mount for it. i have a zx12 light waiting to mount.mark1122 wrote:Nice score on the mic 29's. your bike is weet. i must join the rest and pester u for more details. lol
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thane_420
Re: kz gsx-r swap
16 Mar 2010 21:08
body in primer... notice the changes...
smoothed the tail where it went around the old shock mount location
also the old seat lock hole and other hole from factory in the left hand side cover(which is right one in pic)
Re: kz gsx-r swap
17 Mar 2010 07:21
nice little details.too bad most won't snap,to what you did.
- testarossa
Re: kz gsx-r swap
17 Mar 2010 07:39
Nice subtle changes. I'm planning on doing the same thing on my tailpiece. What did the gas cap come from? I'm a fan of how your bike is looking. What's the paint gonna look like?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
Re: kz gsx-r swap
17 Mar 2010 07:41 - 17 Mar 2010 07:43
Nice work .
I have a z1 tank with the same filler mount. trouble is , it sits too far forward and hits my zx9 forks, and when i move it back it hits the seat pan. i will work it out somehow though.
I take it that your is a KZ tank?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 17 Mar 2010 07:43 by mark1122.
- thane_420
Re: kz gsx-r swap
17 Mar 2010 12:27
gas filler hole is from a older gsx-r tank, i dont know what year and the gas cap is from a gsx-r also but from a newer model b/c the cap is vented, from what i have seen the older gsx-r caps are not vented, they had a vent mounted on front of tank, newer model caps are vented
- thane_420
Re: kz gsx-r swap
17 Mar 2010 12:44
pic of tail light mount... i used a piece metal 1.5" x 4" (roughly) and bent opposite corners and then bonded a tab inside tail to catch tab on light...light is off a H*#%a somthing...have to dig thru papers to find model/year
light is led with intergraded turn signals
light mounted on my z1...its not the best mounts...need to make a cover for it
pic at night of turn signal
