kz gsx-r swap
- irishwill
Re: kz gsx-r swap
17 Mar 2010 20:08
oh...and super cool motorcycle you have there sir....very nicely done!
- thane_420
Re: kz gsx-r swap
17 Mar 2010 23:53
mark1122 wrote
On the KZ, and ltd tanks the bottom seam is very visible, on the z1 the seam is way underneath.
I cant get a good side view of your tank, but it looks more like a kz,z1 than ltd?
The Ltd has more of a smaller stubyyer teardrop shape. the kz and z1 are very similar in shape, but the z1 is smaller.[/quote]
i forgot about the seams on tank...my z1 tank seam is way underneath and my ltd tank seam is visible...i will have to set them beside eachother and take a closer look... i know that the tank on 76 is a ltd b/c it has that goofy vacuum controled petcock...from what i understand they put that petcock on the 76 kz900ltd only? i once owned (sold to my friend) a 77 kz1000ltd that was bone stock and had a small stubby tank on it
73 kz900 1075,mre clutch,race cut tranny,cams,airshift,34 flatslides, custom rear wheel
76 kz900LTD gsx-r suspension swap, mikuni 29mm smoothbores, stock engine
72 suzuki gt750 2-stroke triple
- mark1122
- Keep twisting it
Re: kz gsx-r swap
18 Mar 2010 06:01
thane_420 wrote:
i forgot about the seams on tank...my z1 tank seam is way underneath and my ltd tank seam is visible...i will have to set them beside eachother and take a closer look... i know that the tank on 76 is a ltd b/c it has that goofy vacuum controled petcock...from what i understand they put that petcock on the 76 kz900ltd only? i once owned (sold to my friend) a 77 kz1000ltd that was bone stock and had a small stubby tank on it[/quote]
My understanding is that all LTD tanks look the same, Small and stubby.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thane_420
Re: kz gsx-r swap
18 Mar 2010 08:01
his 1000ltd had the 3.4 gallon tank... my 900ltd has the bigger 4.7 gallon tank and that is the same size as z1 4.7 gallon
Re: kz gsx-r swap
18 Mar 2010 09:56
1976 KZ900-B1 LTD has oem manual petcock (not vacuum petcock).
- thane_420
Re: kz gsx-r swap
18 Mar 2010 10:25
what year/model had vacuum petcock then?
- Darkangel
Re: kz gsx-r swap
18 Mar 2010 11:04
Hey would that tail off the KZ900 work with a KZ1100 or is the frame to wide to make it fit.
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
Re: kz gsx-r swap
18 Mar 2010 11:33
thane_420 wrote:
1977 KZ1000-A1 (standard model) has oem manual petcock.
1978 KZ1000-A2 (standard model) has oem vacuum petcock.
I believe LTD models continued oem manual petcocks through 1980, and that 1981 KZ1000-K1 LTD has oem vacuum petcock.
- mark1122
- Keep twisting it
Re: kz gsx-r swap
18 Mar 2010 20:11
thane_420 wrote:
Thats the first time i've heard that. i always thought all LTD tanks were the same .his 1000ltd had the 3.4 gallon tank... my 900ltd has the bigger 4.7 gallon tank and that is the same size as z1 4.7 gallon
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Re: kz gsx-r swap
18 Mar 2010 20:17 - 18 Mar 2010 20:22
mark1122 wrote:
Perhaps the oem KZ900-B1 LTD fuel tank had been replaced with the larger fuel tank from a standard model KZ900 (or possibly standard model KZ1000).
Which may also explain the vacuum petcock, which appeared on the 1978 KZ1000-A2 standard model.
thane_420 wrote:Thats the first time i've heard that. i always thought all LTD tanks were the same .his 1000ltd had the 3.4 gallon tank... my 900ltd has the bigger 4.7 gallon tank and that is the same size as z1 4.7 gallon
Last edit: 18 Mar 2010 20:22 by Patton.
- kzstreetfighter71
- Atlantic West Coast
Re: kz gsx-r swap
18 Mar 2010 21:19
real nice work!!! looks like we have alot of the same going on,im about a week from finishing, i hope mine rides as good as yours looks like it does.
- irishwill
Re: kz gsx-r swap
19 Mar 2010 14:10
irishwill wrote:
Not to mention the effect of the better rubber thats available for the 17 inch rims
trianglelaguna wrote:i am also going to have "my" swingarm braced and that "will" require me delving into possible frame gussets ,as the new stiffness"will' effect the bikes current smooth flow...i'm not saying that a upside down cartridge fork is not stiffer and much more compliant,i am saying that it is too short to offset the upgrades flaws....
there is very little you could do to a well valved ,sprung,braced,and tire shod kz front end...to improve upon the bikes set in and tracking of the frames rakes.....other than start fresh with a harris or egli or bimota type perimeter frame...simply putting a gsxr front end on it actualy is gonna lmake it worse.imo...i started a thread in chit chat to discuss this topic...sorry to hi jck...also i am a fan of some of the builds....i just wanna be on the side that screams"the king has no clothes"
peace...also..valatino would not be able to ride one of these old beasts...they don'y pay him enough.... as stock 90's 600 will always be able to blow a kz away on a good caynon..,all things being equal.....
well I have no "evidence to prove that you are wrong...just the seat of my pants....but I will bet you pink slips that my '75 900 with a gsxr 1000 front end will out brake your stock set up no matter what you've done to it.
and I gues if you spent the money on a set of ohlin piggy back shocks and spent some time setting things up...new springs ect
as well as changed out the swingarm bushings and the steering head bearings....it might ....possibly ....maybe.....still dont think so but who knows...be as good
just my .02
