General help, building electrical harness
- gordone
Re: General help, building electrical harness
17 Dec 2024 02:32I seeUnfortunately notthe crimper you have is for "insulated" closed barrel connectors denoted by the coloured spots on the side) you will need to buy an "open barrel" crimper (they are around 20 euro's for a reasonable set)
Do you have any recommendation on amazon or ebay ?
I see the connector kit have a range off 22-16AWG
Project:
Project:
17 Dec 2024 03:02
- gordone
17 Dec 2024 09:47
I have some more questions
1. When you pulling cables from rear to front, for the switches, light etc... you want to drop of some cabels to horn and the coils example how do you do that if you are not using tapes, but sleeve? Do you need to have two parallel sleeves than?
I guess it easier to use tapes, but modern sleeves looks more modern to use?
2. I`m planning to run one or two ground cables from rear to front, but what option do I have to collect all ground cabels in rear, I also want it to looks nice
to have many ground cabels on the battery is not looking nice... Maybe I can collect on the start relay.... and is the best way to collect the ground cable using butt connectors?
Project:
Project:
17 Dec 2024 10:48 - 17 Dec 2024 10:50At the end of the day making it "nice" isn't easy but it is worth the effortI have some more questions
1. When you pulling cables from rear to front, for the switches, light etc... you want to drop of some cabels to horn and the coils example how do you do that if you are not using tapes, but sleeve? Do you need to have two parallel sleeves than? Take a look at the diagram and instructions below (this is how I would do it)
I guess it easier to use tapes, but modern sleeves looks more modern to use? Agreed
2. I`m planning to run one or two ground cables from rear to front, but what option do I have to collect all ground cabels in rear, I also want it to looks niceto have many ground cabels on the battery is not looking nice... Maybe I can collect on the start relay the only ground on the starter relay is a chassis ground on the mounting bolt.... and is the best way to collect the ground cable using butt connectors? You can splice your grounds to a single cable (12 -14 awg dependent on current) using the method I showed you previously (the splice can be sleeved into the main harness as the factory do) this would give you a single ground to find a home for, if you don't want to run it to the battery you could go the the ground point on the motor that the main battery cable is grounded to
Last edit: 17 Dec 2024 10:50 by Wookie58.
- gordone
17 Dec 2024 10:53
Nice
Do you remove the insulation (for the part that will be inside the bucket) on the main ground cable when you splice out from it or do you cut the main ground cable where you want to splice out?
Project:
Project:
17 Dec 2024 12:01
Don't touch the main ground cable, your splice should have a "ring terminal" that bolts to the same point as the main ground on the motor
- gordone
17 Dec 2024 12:20
Thank you
What about fuses?
The m-unit have built in production each cuircuit. I was thinking one main fuse between battery and the m-unit?
On diagram I have found on google, seems like power from the battery to starter solonoid go straight without fuse?
What about fuses?
Project:
Project:
17 Dec 2024 12:35Thank you
What about fuses?
The m-unit have built in production each cuircuit. I was thinking one main fuse between battery and the m-unit? I believe the instructions for the "M"-unit recommend a 20a fuse in the main supply (individual circuits are protected by "thermal trips" inside the unit)
On diagram I have found on google, seems like power from the battery to starter solonoid go straight without fuse? Starter supply is only fused on current vehicles (due to the electronic technology used to prevent surges) the starter draws upwards of 80amps on cold start so fusing needs specific types of fuses not used on motorcycles (to the best of my knowledge)
- gordone
17 Dec 2024 22:00
Than you again
Then I only have one more question for now
A shortcut in the recitider is not protected by the M-unit, since it`s connected directly to the battery, before the main 40 amp fuse.
Is there any good reason to have a fuse against recitider also ?
Project:
Project:
17 Dec 2024 23:44Any "un-fused" consumer has the potential to be a fire risk - there is nothing stopping you running the regulator/rectifier output through a 30a fuse before the battery (some later bikes had this from factory)Than you again
- gordone
18 Dec 2024 01:00 - 18 Dec 2024 07:45Any "un-fused" consumer has the potential to be a fire risk - there is nothing stopping you running the regulator/rectifier output through a 30a fuse before the battery (some later bikes had this from factory)Than you again
I think I will do that, since the rectifier is the only "un-fused" circuit accept for start motor rest will be protected behind the M-unit as I see it.
Project:
Project:
Last edit: 18 Dec 2024 07:45 by gordone.
- gordone
18 Dec 2024 09:41Are you putting the cable in the but before you apply heat and solider or do you heat up the but and fill it will solider before you insert the cables?
I have it know by adding solider to the but first, but are not sure if I apply enougf solider….
Project:
Project:
