General help, building electrical harness
  • H1Vindicator
  • H1Vindicator's Avatar
Re: General help, building electrical harness
03 Dec 2024 09:10 - 03 Dec 2024 09:14
#906609
fyi. cycle terminal has waterproof bullet connectors. bottom of page. www.cycleterminal.com/bullet-terminals.html
use open barrel crimping tool. www.cycleterminal.com/crimp-tools.html
sample usage.
Last edit: 03 Dec 2024 09:14 by H1Vindicator.
  • sf4t7
  • sf4t7's Avatar
03 Dec 2024 13:49 - 03 Dec 2024 21:40
#906615
I also recommend cycleterminal.com.  Joe sells high quality connectors and tools for reasonable prices.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 03 Dec 2024 21:40 by sf4t7. Reason: correction
  • gordone
  • gordone's Avatar Topic Author
04 Dec 2024 01:12 - 04 Dec 2024 01:22
#906618
Thank you for sharing your experience.
The reason you are using sleeve is to avoid mechanical stress on soldering?
Project:
Last edit: 04 Dec 2024 01:22 by gordone.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
04 Dec 2024 01:18
#906619
The metal sleeve does relieve stress but it also allows for a "cleaner" joint especially when joining multiple cables, once taped into a loom it will produce a nicer finish.
  • gordone
04 Dec 2024 01:22
#906620
I know I need to use some Ring terminals at the coils example, what is the best way here, what type to use ? soldering them ?
Project:
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
04 Dec 2024 01:30
#906621
You could solder and heat shrink but good quality crimp connectors would suffice.
  • gordone
10 Dec 2024 22:10
#906795
okey, but I guess need special crimping tool, maybe easier to go for solder and heat shrink?
In general way sometimes we want to solider and sometimes not?
Project:
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
10 Dec 2024 23:31
#906797
It's your choice, you don't have to spend a fortune on your crimping tool and you will need one for the rest of the bullet/multi-plug connectors that you will use in building a harness
  • gordone
11 Dec 2024 08:58
#906818
I understand, I`m was thinking using Deutsch AT-DT type.
Amphenol Deutsch AT-DT Type Connector and Terminals
I have some questions around these:
1. Do I need a chrim tool for these connectors?
2. I understand I need a tool for open them up?
3. On the site they say that the kit fits 16-18 AWG terminals, is these the size include the insulation or only the core of the cabels?
4. I have order these cable kit  mo.unit Cable Kit - CafeRacerWebshop.com
5. Is it possible to go from one size og cable to another with these type of connectors?
Is their other things I need for these kit with Deutsch AT-DT ?
Project:
  • H1Vindicator
11 Dec 2024 13:04 - 11 Dec 2024 13:11
#906823
Open barrel terminals. same as stock. where the terminal is crimped, the terminal grips the wire and grips the insulation. very good/strong.
How-to page. www.cycleterminal.com/crimp-tool-help.html
Correct crimping and crimping checks. photo from the site. buy extra terminal pins for practicing.
Open barrel crimper. crimping tool.
Last edit: 11 Dec 2024 13:11 by H1Vindicator.
  • gordone
11 Dec 2024 13:16
#906825
Thank you and Deutsch AT-DT is open barrel type?
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
11 Dec 2024 13:32
#906827
AFAIK, any male or female single connector whithout insulation is an open barrel type.
Correct me if i´m wrong.....
